Rough Running 4.7 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-13-2013, 10:09 AM
Mayor Mayor is offline
Vehicle: 2002 Dodge Ram
Color: Green
Mayor is on a distinguished road
Default Rough Running 4.7
Good Morning Dodgers. Reaching out for wish fix. I have overheated my 4.7 Ram and its running a little ruff. Codes gave me injector and coil fixes, did those, still running ruff. No water in oil, no steaming exhaust. Is there an electronic sensor somewhere that is telling the Mayor to run like hell till its replaced or re-set?
Old 10-14-2013, 07:29 AM
tjbiker031's Avatar
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Try compression test on all 8 cylinders. Maybe a cylinder leakage test afterwards.
What do you mean by rough? Rough idle, Rough driving down the code. Do you remember which codes came up? Are you sure you purged the system properly of ALL air?
Old 10-14-2013, 11:13 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
When you overheated "the Mayor", you may have baked a vacuum line and caused a leak. Check all your vacuum hoses.
Old 10-15-2013, 11:09 AM
Color: Green
Default Thanks
What do you mean purged?
The codes were P201 and P357. changed them both and they went away.
Doesnt help it run any better it seems.
I checked spark on all 8, a ok.
Waiting for a longer compression instrument.
The rough idle is -that it is low and will stall if I touch the gas and it idles back. If I just start it and don't touch the gas, It will run for a while without stalling so I can stare at the motor a while, pull coils off etc. The front four don't seem to effect the idleing, when I remove the coil wire.
Old 10-15-2013, 11:17 AM
Color: Green
Old 10-16-2013, 12:35 AM
Tommycat Tommycat is offline
Vehicle: 2004 Dodge Ram
Rep:22
Tommycat is on a distinguished road
If I had to guess, I'd say when you overheated you may have warped the heads. Not quite enough to leak antifreeze, but probably enough to lower the compression between two cylinders. You're not gonna like it, but you probably have to take those heads off and get them machined. But do the compression test first. That's a lot less time consuming than removing the heads.
Old 10-16-2013, 07:20 PM
Color: Green
Sounds about right thanks. Waiting for a friend with a longer compression tool. Any good pointers for removing a head if it tests bogeye.
Old 11-07-2013, 08:10 PM
the61 the61 is offline
Vehicle: 2002 dodge ram 4x4
Color: atlantic blue
the61 is on a distinguished road
My vacuum line beside the steering pump was split then there is the one on the canister it was split and the one between the canister's was split.
