Spohn Control Arms Help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-13-2013, 11:00 AM
Gonzo1968's Avatar
Gonzo1968 Gonzo1968 is offline
Vehicle: 2012 Ram Express 1500
Color: Tequila Sunrise
Rep:15
Gonzo1968 is on a distinguished road
Default Spohn Control Arms Help
I added both upper and lower non adjustable arms and an adjustable panhard last weekend. I definitely feel a handling difference. However, it creaks like no tomorrow. Where did I go wrong???
Old 10-13-2013, 09:30 PM
Rep:3347
Did you grease all the joints? Inside the bolt holes as well as the zerks fittings?
Old 10-21-2013, 05:29 PM
Gonzo1968's Avatar
Rep:15
I appreciate the info. Nowhere in the directions does it mention this.
Old 10-21-2013, 08:44 PM
Rep:3347
You can use regular white lithium grease on them. When I ordered my stuff from Spohn I just paid the extra $15 for the tube they carry. It'll last a lifetime as you need very little grease to keep the urethane lubricated.
Old 11-18-2013, 01:17 PM
Gonzo1968's Avatar
Rep:15
I also bought the grease from Spohn. I removed the bolts and greased them and the zerks fittings. It lasted a few days and is creaking again.
Old 11-19-2013, 09:19 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
The joys of poly bushings. I believe you will need to continue greasing the fittings and bushings often.
You did lube the entire fitting, inside and out and all around the sides of the bushings?
Old 11-19-2013, 10:24 PM
Gonzo1968's Avatar
Rep:15
Ditto. I was afraid of that. Thanks for the info.
Old 11-19-2013, 11:43 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Thanks for the info I have been looking for a adjustible panhard for a while now. After looking at their site it looks as though you can buy a special tool to adjust the bushings maybe take them apart and lub them up and put them back together and see what u have. I think that would cure you problem
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 11-24-2013, 02:28 PM
HOTRODHARLEY's Avatar
HOTRODHARLEY HOTRODHARLEY is offline
Vehicle: 2013 Ram factory order
Color: BLACK
Rep:256
HOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the rough
Use the sticky clear grease from Energy Suspension. It's the only way to go with urethane bushings. It's nasty stuff to put on.
http://www.summitracing.com/int/part...1104/overview/
Or for a grease gun:
http://www.hotchkis.net/14_oz_super_grease.html
Belltech 3"/5" Lowering kit. Belltech Rear Swaybar, Flowmaster Y Pipe, Custom 4" Single Exhaust w/ 4" Race Magnaflow, 22" SRT10 Wheels, Moroso Catch Can, Undercover SE Tonneau Cover, Weathertech Techliner Bedliner, Diablosport Trinity w/ Hemifever Tune
Old 11-24-2013, 03:16 PM
Gonzo1968's Avatar
Rep:15
Thanks. I will look into it.
