Cigarette lighter power? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 10-13-2013, 10:25 PM
deep cherry deep cherry is offline
Vehicle: 2013 SLT Bighorn
Trim Level: SLT Bighorn
Color: Deep Cherry Crystal
deep cherry is on a distinguished road
Default Cigarette lighter power?
I went out today to charge up my cell and to my disbelief ,there is no power unless the key is on or acc position? My 2002 had live power to the plug in,s.So they are useless unless key is on!!! Are they protecting us from ourselves? I think this flat out sucks! Don
Old 10-13-2013, 10:31 PM
Rep:3347
The cigarette lighters have always been ignition-on with the time-off delay. My 07 had a 12V constant outlet as well, but that was removed in '09 for the 120V ignition-on outlet option. That plug was not the cigarette lighter though.
Old 10-14-2013, 03:26 AM
Bighorn453 Bighorn453 is offline
Vehicle: 2013 Ram 1500 Big Horn
Rep:59
Bighorn453 will become famous soon enough
Slightly off-topic (but cigarette lighter related):
Does anyone know if tapping the power from the cigarette lighter to turn on a mobile or cb radio with ignition will throw off the electronics system since it's all can-bus?
Or is it not an issue?
I know if you install HID lights they have to have an extra can-bus relay...
Old 10-14-2013, 04:51 AM
Monster5601 Monster5601 is offline
Vehicle: 15 Longhorn 3500
Trim Level: Longhorn
Color: Western brown
Rep:535
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
If you notice, the power outlets have a key on their cover, this indicates that the ignition must be on or accessory for them to have power. If you take a trip in your owners' manual, you will discover that you can change the rear power outlet to be powered all the time.
Take a look at this post, nice picture to help you locate the fuse position.
http://www.ramforumz.com/showpost.ph...2&postcount=22
2013 RAM 1500 CC Hemi Laramie 4x4 in Cherry Red
2015 RAM 3500 CC CTD Longhorn 4x4 SRW in Western Brown
Old 10-14-2013, 09:07 AM
Default fuse
Monster 5601 You made my day!!! Thanks for link.
Old 10-14-2013, 09:09 AM
flyersfan2788's Avatar
flyersfan2788 flyersfan2788 is offline
Trim Level: ST-SXT Appearance
Rep:17
flyersfan2788 is on a distinguished road
I have 3 cigarette lighter spots, two on the lower dash, and one inside the flip-up centre console. The lower left one on the dash, and the one inside the console are acc/on ones, but the one on the lower left of the dash is a constant.
I have the basic ST (up in here in Canada), the Tradesman in the US.
I believe as you go up the trims levels, the lighter adapters get replaced, I am pretty sure where my adapter in the console is, is replaced with the SD card slot.
Old 10-14-2013, 10:35 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Actually my 2012 has both on the front console, the left one is key'ed and the right one is constant. They are not cigarette lighters but regular 12 volt sockets.
Old 10-17-2013, 07:14 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
i've tapped mine for the gps...
running a cb tho i'd prob use a relay, they suck a lot more juice than a little ol' garmin
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 10-17-2013, 07:27 PM
Rep:2954
My CB is powered directly from the battery & then into a store bought fuse block that was fastened to the firewall, then it goes to the CB.
The fuse block has 4 places for fuses, my CB, orange rotating lights, & auxilliary fuel tank pump are routed through it
the CB is powered directly, the other 2 are controlled by lighted rocker switches
