Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
MOPAR DECALS
Old 10-14-2013, 04:43 AM
Nck's Avatar
Nck Nck is offline
Vehicle: 2nd Gen 2002 RAM 2500 24V
Trim Level: Laramie SLT
Color: Light brown/Goldish
Rep:74
Nck will become famous soon enough
Default Freon Evacuation.
I know it is illegal to just let it out. But is there anyway I can do it myself?
I have to replace my a/c compressor because the clutch is shot and causes a loud satanic squeal. I'm doing it myself. As for the freon, I might have to take it in to have it drained.
Old 10-14-2013, 11:56 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
You may be able to rent a recovery bottle at your local parts store, then reuse what you recover. But, once you put the new compressor on, you're gonna have to connect a vacuum pump and bring your lines down to a vacuum. Do you have that equipment?
Old 10-18-2013, 06:57 AM
Nck's Avatar
Nck Nck is offline
Rep:74
I'll check that out. And what do you mean by bring the lines down to a vacuum exactly?
Old 10-18-2013, 08:59 AM
Rep:2968
Once you hook all the lines back up to the dryer, accumulator, compressor and condenser, you must put a vacuum pump on the system and put negative pressure in the system and let it set for a half hour or so. This does 2 things, 1) ensures that you don't have any leaks and B) will boil off any residual condensation you have in the lines.
Old 10-19-2013, 04:02 AM
Nck's Avatar
Nck Nck is offline
Rep:74
Alright. Is it possible to rent that equipment? Or maybe I can just install the compressor and then take it down to have that done?
Old 10-19-2013, 11:47 AM
Rep:2968
You probably can rent it, or install the compressor yourself and then take it to a shop that can do it.
Old 10-25-2013, 06:16 AM
Nck's Avatar
Nck Nck is offline
Rep:74
I've decided what I might do. I will have my local shop evacuate everything and then I will install the compressor myself, and then I will take it back to have the vacuum, oil, and recharge done.
Old 10-25-2013, 05:43 PM
Rep:2968
Sounds like a plan. Let us know how it turns out.
