Old 10-14-2013, 08:54 PM
Sabyre Sabyre is offline
Vehicle: 2002 RAM 1500 Quad Cab Sport
Color: RED
Sabyre is on a distinguished road
Cool Drivers Side CV Stuck
Drivers side bearing/hub is bad so I am replacing it. Fairly simple task, got everything off very easily. CV shaft will not slide out of the diff. I did some research to see if maybe there was a clip or something I was missing, apparently cv axle is supposed to simply slide off.
I can only move it a couple of millimeters in either direction. My guess is that I am not moving the cv on the intermediate shaft, rather moving the intermediate shaft inside the diff and the cv is rust welded to the intermediate shaft.
From what I understand the cv is female and slides over the intermediate shaft and subject to moisture and salt getting in between. I think a smarter move would have been to make both ends of the cv shaft male.
Am I missing something? Is there a trick? I watched a video of some guy using a small pry bar and accomplished this task with ease.
Thanks
"We are the music makers and we are the dreamers of the dreams" - Willy Wonka
Old 10-18-2013, 10:59 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
How much pressure/force have you used to get the shaft out? You may want to get a slide puller, attach it to the shaft and give it a few good tugs. A big dead blow hammer may work as well.
Old 10-19-2013, 09:05 PM
Color: RED
I ended up separating the upper ball joint and tire rod end, after that I was able to gain access to the three bolts for hub and there was no need to continue to fuss with the CV axle.
Old 10-19-2013, 09:21 PM
Rep:2616
there is a youtube video about it
it was made by ERIC the Car Guy, http://www.ericthecarguy.com/
i believe there is another one made by http://www.1aauto.com
cv axle removal, wheel bearing front 4x4
