Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 10-15-2013, 04:43 AM
trahornio78 trahornio78 is offline
trahornio78 is on a distinguished road
Default Surging Engine on startup...WTF?
I have a 2002 Ram 1500 with a 4.7L engine. I've been trying tackle this issue I've been having when I start my truck. No matter if it's hot or cold. The engine surges at a super high RPM and then will idle high and erratic. I can tap on the gas to get the RPM to come down a little, but it still has a bad idle and is sitting at a higher then normal RPM. I've been looking for vacuum leaks but haven't found anything. Does anyone know what the hell is going on here?
Old 10-15-2013, 05:32 AM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
That sounds like it could be the throttle body positioning sensor. Sometime carbon deposits can build up inside the throttle body and cause that condition.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 10-15-2013, 06:42 AM
Arth's Avatar
Arth Arth is offline
Vehicle: 2015 GMC Sierra
Color: Bronze Alloy Metallic
Rep:2035
I agree it definitely sounds like a sensor. There are a few sensors that help control Idle but I think that would be the first one due to the age of the truck. Pull off your throttle body and clean it as well.
That would be my first step. Easy, cheap, and straight forward.
Chrome... in moderation.
Old 10-15-2013, 11:29 AM
anothernewb's Avatar
anothernewb anothernewb is offline
Vehicle: 2013 Laramie Crew Cab
Color: Dark Cherry
Rep:168
anothernewb has a spectacular aura aboutanothernewb has a spectacular aura about
check the TPS, followed by the IAC and then the MAF. one of those, if not a vaccuum leak is most likely your issue.
Livin life one truck payment at a time.
Old 11-07-2013, 08:12 PM
the61 the61 is offline
Vehicle: 2002 dodge ram 4x4
Color: atlantic blue
the61 is on a distinguished road
After the day I had I vote vacuum leak. Follow the hiss
Old 11-21-2013, 04:30 PM
slimpick slimpick is offline
Vehicle: 2002 Dodge Ram 1500 2WD
slimpick is on a distinguished road
Check out this thread:
http://www.ramforumz.com/showthread.php?t=93991
Old 11-29-2013, 02:38 PM
JimCash JimCash is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: SLT Quad Cab
Color: Dark Blue
JimCash is on a distinguished road
So what happened with this one? Im with whoever said the TPS or a vacuum line. Anyone ever removed the air line on the fuel pressure regulator? it causes the exact same symptoms.
