Old 10-15-2013, 09:06 AM
skydver skydver is offline
Vehicle: 1998 dodge ram quad cab
Trim Level: lamarie
Color: driftwood (silver)
skydver is on a distinguished road
Default first post and alternator problem
I have a 1998 ram quad cab. 5.9 "Z" code on vin.(original owner). The alternator is charging weakly. when I turn on lights and a/c I get a check gauges light and the charge shows the bottom acceptable line. when I turn off the lights and a/c the light goes out and the gauge climbs about a needle width above the minimum line (slowly).I can turn on lights OR a/c with no problems, it only happens with both on.(compressor running only). The alternator has 256000 miles give or take. It was working fine until I changed a heater hose and had to remove it to get to the hose clamp. when I reinstalled it and drove truck I noticed it. The battery was replaced less than 100 miles ago. what is the "box" mounted to the back of the alternator? I had to remove it from the alternator to remove alternator as it was in the wiring harness but it was installed exactly like it came off as it only goes on 1 way. I have checked all connections especially ground connections and they have been found to be tight and corrosion free. Help. What did I do wrong, or what is now dead?
Old 10-15-2013, 10:38 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I think it's just bad timing. Congrats on getting a quarter of a million miles on your truck, that's pretty darn impressive. But maybe it's time to swap the alternator.
Old 10-15-2013, 07:29 PM
ramfam's Avatar
ramfam ramfam is online now
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Sounds like you need to field test alt to rule out volt regulaor from the sound of it. Cause it could be ether going bad hope its alt and not reg. Its done by the computer. Now if it is reg in computer there is a way arround it I think warlock did it in his truck.
Old 10-16-2013, 09:15 AM
Trim Level: lamarie
well today I am a VERY happy dodge truck owner. Found the problem.......drum roll.........It was the 140amp fusable link. $3.99 at advance auto. Had power out of alternator (28vdc) and at battery it showed only the deminishing battery voltage. found blown fuse. all fixed and looking for another 100000 miles.
Old 10-16-2013, 10:02 AM
Rep:2929
Voonderbar! Thanks for the update! Here's to another 100000 miles!
Old 10-31-2013, 06:29 PM
raydoz raydoz is offline
Vehicle: 1998 Dodge Ram
raydoz is on a distinguished road
You said in your reply that Warlock had a way around the voltage regulator. I heard that also. Can you tell me how to get a question to Warlock ?
Old 10-31-2013, 07:44 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
POOF!
Seek and ye shall find...
Let me find the thread because it takes a little typing.
Here's a quickie, second page: http://ramforumz.com/showthread.php?t=141534&page=2
