Old 10-19-2013, 03:57 PM
Rep:2640
i will add the rest, when i get back from lunch
Old 10-19-2013, 05:53 PM
dixon4420's Avatar
dixon4420 dixon4420 is offline
Vehicle: 2007 dodge ram 1500
dixon4420 is on a distinguished road
Nice set up there.
Old 10-19-2013, 06:07 PM
Rep:2640
Ram power switch ON
Auxilliary Pump Switch ON
i don't know what measuring system the read out uses, SAE or Metric ???
i had to re route the hose, i didn't want people to see it, it used to lay in the bed, right here
Old 10-20-2013, 03:51 PM
Rep:2640
I thought that someone was interested enough to at least read this post ??
Old 10-20-2013, 04:51 PM
Canadian Hemi Pride's Avatar
IDFWY
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
GT, that is a crazy set up you got going. With all the driving you do aswell, it must very handy your set up.
Tow mirrors up for the haters
Old 10-20-2013, 05:08 PM
Rep:2640
The tank was expensive, but it is paying for itself at $12 a fill up, plus convenience
40 cents a gallon X 30 gallons per fill up over in Yuma Arizona
As far as work goes, i already have had 2 calls to do jobs tomorrow, i accepted one of them & if everything goes well, i may get to do the 2nd one, he is waiting on a Transportation Permit so that he can travel with his Oversized Load
Old 10-21-2013, 10:01 PM
nite ryder's Avatar
nite ryder nite ryder is offline
Vehicle: 2003 Dodge Ram
nite ryder is on a distinguished road
Yeah GT hit the nail on the head with post #16. I have an aux tank in my tool box along with an electric fuel pump. The outlet line from the fuel pump goes through the sheet metal near the left front corner of the bed, just under the rail. It goes down between the inner bed sheet metal and the outter bed sheet metal and ends near the filler tube of the fuel tank. Near that filler tube is another smaller tube that is an overflow breather tube, one end of it goes to the tank and the other end of it goes to an area near the top of the filler tube. I put a T which was the size of the two tubes in this smaller breather tube. When I want to fill my main tank I unscrew the gas cap on the filler tube (don't know if this is necessary) and flip the switch that controls the electric fuel pump. I have found that a fuel pump is needed even tho the aux tank is above the main tank, gravity feed for some reason will not work. I used the T and the breather tube because connecting to it was easier than putting another inlet into the metal filler neck, and the fuel ends up the same place, in your fuel tank. I've used this aux fuel tank many times when I'm pulling a 5th wheel trailer, just knowing you have some extra fuel is a nice feeling.
"When you have a lot of things to do, it's best to get your nap out of the way first."
Old 10-25-2013, 07:49 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Fantastic set up, Props to you Sir. if I knew how to give rep points I would. Wait why don't you do a post Aux Fuel Tanks and I'm sure someone will be able to give you rep points.. just a tought
Old 10-28-2013, 08:55 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
51 extra gallons? Plus the 32 gallons? Are you planning on driving to China? That's over 80 gallons or almost $300 of fuel weighing over 700 pounds.
If you were hauling near the trucks two limit and you were crossing the West and the desert regularly, it would make sense. But remember this, you will still have to stop to drain the lizard. So that's what you have to consider.
