MPG Report - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2014 Dodge Ram Forum
Diesel Forums!
Dodge Caliber
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Place your Ad Here!
Old 10-15-2013, 09:08 PM
Darwin00537 Darwin00537 is offline
Vehicle: 2014 Ram 1500
Trim Level: 4x2 Limited CC SB
Rep:24
Darwin00537 is on a distinguished road
Default MPG Report
Just passed 1100 miles on the odometer and reset the trip meter 200 miles ago. I'm averaging in the 19s. That includes daily commute, driving around the neighborhood, a trip to Costco, and two trips to the airport. BOOM!
Old 10-15-2013, 10:00 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
I thought my mileage would improve but it has not. For ALL local driving, I am getting 16.9 mpg.
Old 10-16-2013, 07:24 AM
nailem nailem is offline
Vehicle: 05' Duramax crew
Rep:18
nailem is on a distinguished road
please list what octain you normally run.
EcoDiesel ordered on 2/28
Build date: 3/28
Ship date: 3/29
Currently: Delivered 4/16
Air suspention, 17"wheels, Bucket seat
Old 10-16-2013, 09:09 AM
Rep:24
The main thing keeping my MPGs up is the highway time. It I did local stop and go driving most of the time I'd be in the 16s as well.
87 Octane.
Old 10-16-2013, 09:10 AM
Monster5601 Monster5601 is offline
Vehicle: 15 Longhorn 3500
Trim Level: Longhorn
Color: Western brown
Rep:492
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Remember that a drop of gasoline, regardless of its octane rating, has exactly the same amount of energy. If you are towing or running a lot in hot weather the rated octane (89) will prevent pre-detanation and allow your engine to extract the full amount of energy from the gas.
Running in a cooler climate, 87 octane and 89 octane will yield the same MPG since pre-detanation is typically not an issue.
2013 RAM 1500 CC Hemi Laramie 4x4 in Cherry Red
2015 RAM 3500 CC CTD Longhorn 4x4 SRW in Western Brown
Old 10-16-2013, 11:57 AM
CanuckShooter CanuckShooter is offline
Vehicle: 2013 Ram
Trim Level: sport
Color: red
CanuckShooter is on a distinguished road
My 2013 1500 Ram Sport has just over 8000K on it now...going back and forth to work, with speeds in 80-100k range the truck has been getting 13.8~14.2 L/100K.
Loaded up and pulling, it has been in the 21~23L/100 range. You can see below what I mean by loaded up. This picture was taken while trying to balance the load. 18' trailer @2000lbs, camper loaded up about 2000lbs, atv 700, and 25 gals of gasoline in dry box.
The 5.7 Hemi handles this pretty easily, but the truck needs a lift and airbags to be really functional.
Old 10-16-2013, 12:09 PM
Droptop87's Avatar
Droptop87 Droptop87 is offline
Rep:40
Droptop87 is on a distinguished road
Yea I have aprox 3700 kms on my sport now if I drive the speed limit Im around 11.5l/100km. On the 36 km trip home if I take the secondary road and keep between 80-90 I can do it at 9.8 So Im pretty happy and I only use supreme or 91 octane
Old 10-16-2013, 12:13 PM
Vehicle: 2013 Ram
Trim Level: sport
Color: red
Wow..that is pretty good...maybe I should try the higher octane....LOL
Old 10-16-2013, 12:40 PM
Rep:18
I'm not an expert on octane but doesn't the compression ratio of the engine play into the equation? Some motors are designed to run on higher octane. My wife's VW said to run 89 we would run 87 and it ran fine but definitely ran better on 89 and got better MPG. Do the Hemi's suggest to run 89
Build date: 3/28
Ship date: 3/29
Old 10-16-2013, 02:08 PM
gwilburn's Avatar
gwilburn gwilburn is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Color: Maximum Steel Metallic
Rep:119
gwilburn will become famous soon enoughgwilburn will become famous soon enough
Everyone needs to understand that octane is nothing more than the relative measure of a fuel's propensity to combust under compression (rather than when your spark plug fires). A diesel actually fires under compression - hence the term "dieseling", or pre-detonation.
So higher octane is no "better" than lower octane, other than the fact that it will withstand higher compression ratios w/out combusting. Many engines of the day will adjust their "timing" based on the octane of the fuel. If lower octane is uses, the ECU "retards" the timing - firing the cylinder before it fires under compression.
I have several "toys" with high performance engines that require 91+ octane. Without it, pre-detonation occurs (which can cause damage) - if detected by the ECU, it backs off the timing resulting in lower performance of the engine.
What does this mean? If the engine is designed for it, running higher octane results in maximum performance. This may or may not translate into better fuel economy. However, if an engine is not designed for higher octane, you are wasting your money using it (and the oil companies love you for it).
BTW - nearly all gas contains the exact same detergents... so it's not "cleaner" either. I do put it in my small engines (mower, snowblower, etc.) because 91+ usually contains little (if any) ethanol, so it stores better.
