Old 10-16-2013, 10:57 AM
mineralram's Avatar
mineralram mineralram is offline
Vehicle: 2015 Dodge Ram
Rep:166
mineralram has a spectacular aura aboutmineralram has a spectacular aura about
Default Brighter Backup Bulbs in an LED equiped Ram
Anybody running Brighter Backup bulbs in a 2013 Ram that is factory equipped with the LED package. I noticed that the Backup bulbs are not LED's and would like to install brighter ones that would increase night vision with backup camera.
Old 10-16-2013, 11:21 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I ordered a set of HID backup lights. I am still waiting for them to show up, they are on the slow boat from China. Should be here today.
I will post if I can get them to work or not. Not sure if the wiring has enough power to fire the ballast or if they will hyper flash. Rolling the dice again on another Mod.
Item is here: http://www.aliexpress.com/item/HID-R...761205345.html
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-16-2013, 11:50 AM
atmotocrosser atmotocrosser is offline
Vehicle: 2014 Ram
Trim Level: 1500 Express QC 4x4
atmotocrosser is on a distinguished road
I'm tagging along since I'm interested in this too.
Old 10-16-2013, 11:53 AM
Sohighlyunlikely Sohighlyunlikely is offline
Vehicle: 2013 Dodge Ram
Trim Level: Black Express
Sohighlyunlikely is on a distinguished road
Greg
I had ordered something from them earlier this year. After waiting for a month. It hadn't even shipped. I hounded them and eventualy got a full refund.
Doc
Old 10-16-2013, 12:18 PM
Monster5601 Monster5601 is offline
Vehicle: 13 Laramie 1500, 15 Longhorn
Trim Level: Longhorn
Color: Western brown
Rep:470
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
My concern would be the start-up time it takes for a HID to go to full output.
Me three.
2013 RAM 1500 CC Hemi Laramie 4x4 in Cherry Red
2015 RAM 3500 CC CTD Longhorn 4x4 SRW in Western Brown
Old 10-17-2013, 04:58 AM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
The stock backup lights on my 2013 Laramie Longhorn are a lot brighter than the ones on my 2010 F150 were.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 10-17-2013, 08:33 AM
Asur Asur is offline
Vehicle: .
Rep:4373
I have a set of HID backup units, there great, at start up they are the same lumans as the OE bulb, but after about 3 sec's they are very strong. You can also get backup LED bulbs from many places but I tried a few, because of the way the reflector and the position of the bulb is in the Ram you need to get bulbs that have Side led's for a good light output.
Old 10-17-2013, 09:12 AM
gcscott's Avatar
Rep:1043
Greg
I got the HID lights.
I tested the lights with my 12v power supply and they fired up. Went out to the truck and Installed one side to see what I get and the HID light flashed 3 times, stopped, flashed 3 more times, than got nothing.
I put in the OEM bulb and got nothing, no power in the circuit. Turned off the engine and than restarted. OEM bulb relight. Not enough power to fire the HID ballast. Dam electrical system!
My next attempt will be trying to use power from the 7 pin trailer plug wiring where I have my light bar wired into the reverse light.
This is not going to be plug & play if it works. Will update.
Greg
Old 10-17-2013, 09:25 AM
Color: White/Gold
Rep:487
Greg
That's one of the reason I've learned not to modify any of the electrical, suspension or mechanical systems on these late models. The benefits may not out weigh the potential issues.
Old 10-17-2013, 11:07 AM
GilAlex's Avatar
GilAlex GilAlex is offline
Vehicle: 2013 RAM 1500 Express RCSB 4x4
GilAlex is on a distinguished road
I used 9 SMD 921 bulbs in my 2013 RAM Express.
They are really bright and did not cost a lot of money.
Try iJDMToy.com or BrightLEDLights.com
There is probably enough room for 13 SMD 921 bulbs.
Gil Alexander
2013 RAM 1500 Express SB 4x4 - Flame Red
