Old 11-02-2013, 09:49 AM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
Originally Posted by gcscott View Post
Did you try putting the factory bulbs back in, run the engine so the code goes away, than change back to the LED bulbs?
When I put the HID bulbs in, I removed the factory bulbs and left the sockets empty with no bulbs in them. I don't get any codes for backup lights out.
It seems nothing I do will keep the failure code form showing its ugly head if I re-installed the LED bulbs. It looks as though the stock bulbs are going back in and I'm going to stop listening to advice about using LED bulbs. The stock bulbs were plenty bright enough.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 11-02-2013, 11:12 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Sorry you can't get it to work for you.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-29-2013, 08:50 PM
ediram ediram is offline
Vehicle: 2014 Ram 1500 Sport
Rep:52
ediram will become famous soon enough
Silvercreek the answer to get rid of the code is easy... buy LED lights with the built in resistor, I did in my Laramie and had no error codes flash. BUT, no one has answered my question from a few weeks ago. I put in the LED and in reverse the back up camera screen goes 20% fussy and flickers. Can someone solve this issue. for now i put the factor lights back in and put the LED's in my wife's CRV, amazing how bright they are.
Let me know on the fussy flickering screen issue with the LED'S... please.
Old 11-30-2013, 06:32 AM
Firemedic10584 Firemedic10584 is offline
Vehicle: 2013 Ram 1500 Sport
Rep:120
Firemedic10584 will become famous soon enoughFiremedic10584 will become famous soon enough
I just emailed the guy mentioned on page 2 but seeing how everyone is have the error message, I don't know that I'm going to order them. Ill ask him if he has any lights with built in resistors. If not, Ill be sticking with the stock bulbs
Old 11-30-2013, 10:50 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Try this Company "autoluminationdotcom" Contact Chris Bacon at
Email:
superlumination@cox.net
they have every type of LED Bulbs out there that will work with almost any American and European Vehicle, tell him your truck, year, version, bulb you want and if you have EVIC he should be able to give you the bulbs you need. I have bought a bunch of bulbs for different vehicles from this guy and his stuff works well and he has some of the brightest bulbs I have seen. Hope this helps
Old 11-30-2013, 12:56 PM
Rep:52
thanks i'll send an email with my issue and see what they say.
needing a resistor in place is very common in locations that are monitored, the other issue is a hyper flash which is to warn the driver a bulb is out. the led's draw such little power that the vehicles think the bulb is out, the resistor creates the resistance the bulb would normally create.
Old 11-30-2013, 05:22 PM
Rep:52
Email:
Spoke to Chris, he said the issue is the regulator in the LED's and that is what's creating the flickering and snowy screen, I've asked if he has any suggestions.
Old 12-03-2013, 07:10 AM
Rep:120
I ordered 2 of the Samsung 7440 projector lights from the guy mentioned in this thread. Hopefully I don't get any error messages!
Old 12-03-2013, 10:56 PM
Rep:52
let us know how you make out. don't be surprised if you need to add a resistor.
Old 12-04-2013, 08:39 AM
Vehicle: .
Rep:4373
+1 on that, keep us informed, also can you post a link on what you picked up? or a pic?
