Old 10-16-2013, 11:33 PM
EugeneFire304 EugeneFire304 is offline
Vehicle: 2013 Dodge Ram Sport crew 6'4"
EugeneFire304 is on a distinguished road
Default Bilstein 5100s... Height Choice Assistance
I've got a new '13 Sport that I'm going to level with Bilstein 5100s for ride improvement and for a new set of 275/65r20's. The overall difference in tire diameter is only an inch. I'd like to maintain a little rake for the occasional haul or tow. Which detent do you think would be best? I'm thinking the 1.4" or 2.1" probably but I'll defer to those that have more experience with the Ram. Thanks!
Old 10-16-2013, 11:42 PM
Grubrunner's Avatar
Rep:3883
I too like the slight rake appearance.
2.1 setting is the optimal setting, IMHO.
I preferred that route but couldn't with my setup. I have no regrets.
Truth be known, these trucks are not a mirror image of one-another. That being, what works on one model is not a sure thing on an identical.
It's really a trial & error thing.
2.1 setting rake may not give you the visual appearance you want so try it out.
Grub out!
Old 10-17-2013, 01:03 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1109
I did this last week and I went w 2.1" w a view to running a slightly larger tire down the line.
Bilstein 5100s @ 2.1", CF wrapped dash, De-badged, Extang Solidfold tonneau, Goodyear Wrangler Duratracs (285/60/20), Husky Weatherbeaters, Magnaflow 18" muffler, Mufflex 5" tips.
Old 10-17-2013, 03:14 AM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
The best way to determine what you need to set them at is to measure your truck as it sits now. Get it on level ground and measure all 4 fender heights to determine your rake. From there you can do the math to figure out what you need them at. 0.5" of rake will look dead level to the eye so you're going to want at least 1" if not slightly more.
Old 10-17-2013, 06:57 AM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
imo, 2.1 is the way to go
it'll sag a hair over time and prob a little moreso on a crew compared to a reg or quad
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 10-17-2013, 09:49 AM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
2.1 put my CC/6'4" 4x4 dead level fresh off the install - as measured at the fenders. After installing .750 spacers and Airlift 1K's @ 5 psi in the rear, it has 1" of measured rake after some time to settle in.
As the others have said, YMMV...
- DAA
Old 10-17-2013, 11:17 AM
Thanks everyone for your replies. Just FMI, if I went 1.4", would it cause any issues with rubbing the slightly larger tires?
Old 10-17-2013, 11:36 AM
Whiplash's Avatar
Color: Black Gold
Rep:177
i wouldn't think it would rub
you're going up 1.4" of spacing from top of tire to fenderwell
tire is only increasing within that space .5" (radius)
i'm def. no expert, so wait for one of the other guys to jump in here...but that's how i see it (i'm still learning too, so if my logic is wrong i'd like to know )
Old 10-17-2013, 11:45 AM
Rep:2026
What exactly are you considering as slightly larger tires?
It's not the reduced spacing on the top that will make you rub. It's the fact that the whole wheel well is now lower. You'd end up rubbing on the front or back of the inner fender. But that all depends on how big of a tire you plan on putting on. If you do plan on stepping up in tire size it probably makes more sense to go to 2.1" anyways other wise you're tires are going to look a little stuffed in the wheel well.
Old 10-17-2013, 12:16 PM
wmorris4x4's Avatar
wmorris4x4 wmorris4x4 is offline
Vehicle: 2013 Ram 1500 Sport 4x4 5.7
Color: 1ea Bright CherryRed 1ea White
wmorris4x4 is on a distinguished road
Default 2.1 with 305,s
Mine is set at 2.1 and i run 305/55-20s with aftermarket wheels with no rubbing, didnt like the 2.8 or less than 2.1 i also 1000airlift in ass end aired to level trailer i pull.
