Old 10-18-2013, 07:50 PM
jeb6294 jeb6294 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: SLT - Big Horn
Color: Grey
Rep:18
jeb6294 is on a distinguished road
Default WTF is that Noise?
Got the truck back from the dealer today. Hopefully they got the squeal fixed but now there's a new issue. WTF is this noise coming from the dash?
Trying to do this from my phone so hopefully this works.
Old 10-18-2013, 07:53 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Could be a solenoid in the heater box area under the dash.
Old 10-18-2013, 08:21 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
That's not coming from a speaker, is it? It's from the dash? Man, that's horrendous! Is it constant?
Old 10-18-2013, 08:40 PM
Color: Grey
Rep:18
So far it has been pretty constant for a couple minutes after starting it. After that it usually goes away. I can hear some from the speakers but it definitely sounds like it's coming from the dash. Turning the radio on or off doesn't seem to affect it. It'll also keep doing it if I turn the truck off. The solonoid could work because the vents quit working at the same time, all the air comes out at the floor, but turning the HVAC on or off doesn't seem to affect it either.
Old 10-18-2013, 08:44 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
I think the louver/door that changes the airflow from floor/dash/defrost, or the one that selects outside air/recirulate is jammed and gear is slipping. Does it make a difference what setting these are at?
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 10-18-2013, 09:00 PM
Color: Grey
Rep:18
It's hard to say. I can turn it from outside to recirc or from vent to floor and it doesn't stop but it could just be one of those things that's immediate. Is that something that would cycle when you first start it even if the heat/air is turned off?
Old 10-18-2013, 09:14 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
wow, that's brutal...i'd be taking it right back to the dealer
was it like that when you picked it up? if not, what changes did you make since getting it back?
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 10-18-2013, 11:18 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
Yup, most likely the blend door motor for the AC is stripped. Same sound mine had.
Don't hear about it to often any more, but motors still can go bad.
Just check to see when you change positions, defrost, vents etc, that the air flow comes from the position selected. If it is stuck on the floor it is the blend door motor.
Back to the dealer unfortunately.
Old 10-19-2013, 03:09 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Sounds like you picked up woody wood pecker and he's hiding in your dash.
But ya all jokes being said it does sound like your blend door motor, I would be seeing my dealer about it for sure.
Old 10-19-2013, 06:57 PM
Rep:233
If you feel adventurous, you can always do the work your self.
I should have provided this link in my other post.
http://www.ramforumz.com/showpost.ph...6&postcount=11
