How to program a garage door opener - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-18-2013, 08:04 PM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1503
KA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant future
Default How to program a garage door opener
Hey all, I am visiting my parents and forgot my copy of their house key. They have a garage with openers and it dawned on me this afternoon that I could program one of them to my truck's upper console buttons (I, II, III). Problem is, I do not have my manual with me. Can someone post instructions on how I would go about doing this? Thanks!!
Old 10-18-2013, 08:20 PM
Arth's Avatar
Arth Arth is offline
Vehicle: 2015 GMC Sierra
Color: Bronze Alloy Metallic
Rep:2035
To program it's easy... I actually have it memorized.
But because I am lazy..
1. Turn the ignition switch to the ON/RUN position.
2. Place the hand-held transmitter 1 to 3 inches (3 to
8 cm) away from the HomeLink button you wish to
program.
3. Simultaneously press and hold both the Homelink
button you want to program and the hand-held transmitter
button.
4. Continue to hold buttons until the EVIC display
changes from “CHANNEL # TRAINING” to “CHANNEL
# TRAINED”, then release both buttons.
If it has a rolling code do this after you have done the above step...
5. At the garage door opener motor (in the garage),
locate the “LEARN” or “TRAINING” button. This can
usually be found where the hanging antenna wire is
attached to the garage door opener/device motor. Firmly
press and release the “LEARN” or “TRAINING” button.
On some garage door openers/devices there may be a
light that blinks when the garage door opener/device is
in the LEARN/TRAIN mode.
NOTE: You have 30 seconds in which to initiate the next
step after the LEARN button has been pressed.
6. Return to the vehicle and press the programmed
HomeLink button twice (holding the button for two
seconds each time). The EVIC will display “CHANNEL #
TRANSMIT”. If the garage door opener/device activates,
programming is complete.
Chrome... in moderation.
Old 10-18-2013, 08:31 PM
KA1OTE's Avatar
Ram Ham
Rep:1503
Thanks so much! Trained and done!
Old 10-19-2013, 09:17 PM
Northman11 Northman11 is offline
Vehicle: 2012 Black Sport CC
Northman11 is on a distinguished road
I had to do the very same thing tonight so thanks again for the instructions.
Old 10-20-2013, 11:16 PM
simon7204's Avatar
simon7204 simon7204 is offline
Vehicle: 2012 Ram 1500 Sport 4x4
Color: Grey
simon7204 is on a distinguished road
Great instructions; just did mine and works perfectly! I tried previously programming but to no avail; thought my garage door opener was not compatible. Thanks for the instructions!
Old 01-15-2016, 04:39 PM
Deer Hunter's Avatar
Deer Hunter Deer Hunter is offline
Vehicle: 2015 Dodge Ram Laramie
Trim Level: Laramie 4x4
Deer Hunter is on a distinguished road
program.
button.
I had to press mine a 3rd time on my 2015 Laramie to get it working. This may help someone else
