ZDOG
Old 10-26-2013, 11:24 PM
sottis sottis is offline
Vehicle: 2010 Dodge Ram Laramie 4x4
sottis is on a distinguished road
I'm trying to figure out how you would break the boots - mine are very flexible rubber. btw, I changed my plugs and didn't break a one.
Old 10-27-2013, 01:23 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Usually if you take care of this stuff per the scheduled maintenance you won't have any issues, but most people wait longer. On this engine the upper plugs(with the boots) are supposed to be changed at 50k miles, I waited until about 75k miles and tore 3 or 4 IIRC. They just get brittle, also it depends on how much dialectric grease is applied up front.
Sean
Old 10-27-2013, 02:01 AM
Rep:2720
you would think that the factory uses dielectric grease, when the assemble them, but its likely they don't
we shouldn't have to pay for their short cuts
Old 10-27-2013, 02:31 AM
snrusnak's Avatar
Rep:1385
they do use dialectric grease(it was on mine, anyway), but waiting 50% longer than the service interval, with all the heat cycles it just doesn't last that long.
Sean
Old 10-29-2013, 09:00 AM
2010x3.92 2010x3.92 is offline
Vehicle: 2010 Ram 1500
Color: Inferno Red
Rep:32
2010x3.92 is on a distinguished road
It's not a defective part. Rubber will fuse to porcelain over thousands of heat cycles. (like stated above). Haven't any of you tried to remove old plug wire boots without a proper plug wire boot tool? 90% of the time if you don't use the tool you will either pull out the wire or the boot will tear and stick on the plug. Try this in an engine where there is no access to this part and you can only remove it by pulling on the top. See what happens.
I have always made a point to grease any plug boot I re install. Prevents busted knuckles and broken parts.
If I was a dealer I wouldn't want to pay for someone's broken coil because they decided to wait until 100k to change plugs that were supposed to be swapped out at 32k.
Old 10-29-2013, 11:06 AM
Flight-ER-Doc Flight-ER-Doc is offline
Vehicle: 2010 Ram 1500 Crew
Color: Inferno Red
Flight-ER-Doc is on a distinguished road
You'll get the same response from the other manufacturers...
I had something (don't recall anymore) break on my GMC Yukon, which the dealer was fixing....and ultimately they screwed up something else and had to replace the intake manifold.
No charge to me.
On my Excursion, the dealer broke the thermostat housing. Replaced for free (I later replaced with a billet unit). No charge to me.
Nissan? Same. Toyota? Same. Honda? Same.
Old 10-29-2013, 07:57 PM
snrusnak's Avatar
Rep:1385
No charge to me.
That's completely different.
If your reread my comments you'll see that I said "It's like that with every manufacturer on these problematic items"
Yes, if the dealer breaks something due to their negligence, they will replace it.
Sean
Old 10-29-2013, 09:46 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
That's the way it is man. I see it all the time at work, I'll pull the coil up and POP the boot breaks off and sticks to the plug, its no one's fault it just happens. So the owner of the tuck has to buy a new coil or run on seven cylinders.
I really love the people who start saying things like "well the tech took the coil off the wrong way!" Really? Do you realize that UP is the only way they can go to come out? REALLY!!?? Sorry started getting carried away there.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 10-29-2013, 09:49 PM
snrusnak's Avatar
Rep:1385
That's the thing, they don't realize. Yes it's a bit of an inconvenience to have the coil possibly break the boot during regular maintenance, but that's also part of the reason you get 310hp out of a 287 cid engine. It's just part of the design, there's no good way to remove it without tearing the boots.
Sean
Old 10-29-2013, 09:56 PM
Rep:73
Exactly...There is literately nothing you can do when removing the coils, if its going to break then its going to break and there's no stopping it. MSD makes 5.7L hemi coils, maybe those are a little more robust?
Check em' out:
