Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 10-20-2013, 06:31 PM
joelemley69's Avatar
joelemley69 joelemley69 is offline
Vehicle: 94 2500 4x4
Trim Level: laramie slt
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
joelemley69 is on a distinguished road
Default lost
hey diesel guys, i got a 94 2500 a couple months ago that has an auto tranny in it. i have been told that if i turn it up with a new plate i can expect to be puttin a tranny in it very soon. is there any mods i can do to get a little power out of it ,such as moving the stock plate, with out killin the tranny and what kind of numbers would that be?
Old 10-20-2013, 09:42 PM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Still got OEM head studs? I'm 24v, so rebuilt & upgraded auto tranny & TC. Did some other improvements. R...
Old 10-20-2013, 10:31 PM
yes, the motor as far as i know has never been touched
Old 10-21-2013, 02:01 AM
Rep:177
Assumes your 46RH Auto tranny is adequate.
You can slide your plate forward on the pump and crank on the star wheel (not full), Google how much to do this - Diesel Bombers forum. Make sure you have a good intake and clean filter (I'm K&N ), run an open 4" and SS 5" tip out the rear. I take my 24v Cummins to my diesel tech and I have a tranny guy. We're talking 50 to 60hp increase over stock for your 12v. Don't block the waste gate.
You should address your OEM head studs (ARP good way to go), upgrade your tranny and TC, and Google the following for adding up to 150 hp:
Cheap horse power 1994 12 valve Cummins
Click on;
Adding 150 HP to affordably built 12 valve B - series Cummins, by Mike McGlothlin. DIESELPOWER Magazine
Good luck, R...
Old 10-21-2013, 09:13 PM
thanks for the info! i plan on doing some stuff to the truck after christmas. new paint, power upgrades, throw a stick shift in it. i've gotten some gd ideas from here. prob gonna be on here alot more bfore too long. thanx again for the help!
Old 10-22-2013, 11:47 PM
Rep:177
You're welcome, it's 47RH auto for Cummins........I think we have a Cummins forum you can sign up for. R...
