Old 10-20-2013, 10:30 PM
Trober's Avatar
Trober Trober is offline
Vehicle: 2006 Dodge Ram 1500 4.7L 2WD
Trober is on a distinguished road
Default 545rfe test ports?
Im trying to put in a trans temp gauge in my 06 ram 4.7 but the sender is 1/8" and doesnt fit either test port. What size are the test port holes? And were can i find a reducer and extender? I ordered the extender from glowshift but it was for the cummins trans they have1/8" test port. Any help would be great ive wanted to install this for along time but cant....
Old 10-21-2013, 08:08 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
You don't want to install a temp sending unit in one of those test ports. Those ports are dead-headed, so they have no flow at all. They are for sensing pressure, not temperature.
For temperature, you should install your sending unit in a tee fitting in the cooler line. The upper line (at the trans) is the "to cooler" line, so that line will have the hottest fluid. You can tap into it wherever along its length is convenient.
If you use the test ports, you will NOT get an accurate temp reading.
