Old 10-22-2013, 04:17 PM
Cush09 Cush09 is offline
Vehicle: 2013 Dodge Ram
Cush09 is on a distinguished road
Default Air Suspension for 2013 Ram Sport
Looking at adding a rear air suspension to my 2013 Ram Sport. Looking at the Air Lift 1000. Just something simple to help out towing my travel trailer. Don't need the built in compressor. Any one install this on their truck and if so how do you like it?
Old 10-22-2013, 05:46 PM
On The Road's Avatar
On The Road On The Road is offline
Vehicle: 2013 1500QC Hemi 4x4 8Spd 3.55
Trim Level: Laramie Frost Beige
Color: Maximum Steel Metallic
Rep:21
On The Road is on a distinguished road
I did the Air Lift 1000 back in June. They're great and simple/straight forward to install. I'm sure it would work well with TT. I run 10 lbs in them normally. Put the air fitting just to the right of the license plate.
Good Luck
RAM 1500 Laramine QC 4X4 Hemi - 8 Spd ZF 8HP70-3.21 -Stainless Steel Door Sill Protectors-Billet Catch Can-Cabin Air Filter Mod -Air Spring 1000's - EGR Hood Shield - TruXudo Lo Pro QT Tonneau Cover-AMP Research Bed Step-DeeZee Bed Rug- Tail Gate Protector-Trimax Spare Tire Lock
Old 10-22-2013, 06:04 PM
Awesome. Thanks for the reply. That helps big time. I'm new to doing these kind of things to trucks so need all the help I can get! Just didn't want to buy something that didn't work properly!
Old 10-22-2013, 08:31 PM
S.FLRAM S.FLRAM is offline
Vehicle: 2013 RAM Quad
Trim Level: Tradesman/Express
Color: Mineral Gey
Rep:38
S.FLRAM is on a distinguished road
Air Lift works great. I installed them with ease. Put 15 80LB bags in my bed with 20LB of air pressure and had minimal drop.
Old 10-23-2013, 11:01 AM
Anyone install the air bags and also install a leveling kit? I want the air bags for towing and the leveling kit for looks. Not sure if doing both is a good idea?
Old 10-23-2013, 11:10 AM
darkstar darkstar is offline
Vehicle: 2013 4x4 express hemi
Trim Level: express
Rep:80
darkstar will become famous soon enough
i have a daystar 2.5 front and 1in rear spacer set with airlift 1000 springs in it
truck has a 550 lbs pallet in the back right now, with 15lbs in the bags, sitting dead level
2013 express RCSB 4x4, 2.5in front, 1in rear lift, AFe stg 2 intake, magnaflow exhaust, Diablo tuned
Old 10-23-2013, 11:53 AM
thanks for the info! I will have to measure my truck and see if I need the rear spacer. Just in the gathering information stage now. Winter is soon coming here in Alberta soon, so probably wait till the spring to do the mods.
