Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 10-22-2013, 08:42 PM
Jared Snyder Jared Snyder is offline
Vehicle: 99 V10 Ram 2500
Color: Green
Jared Snyder is on a distinguished road
Default Cracked heads, Coolant in oil.. Need new heads!
Hey guys Im looking for replacement cylinder heads for my 8.0L V10.. The truck is a 99 2500, first i was suspect of the intake gasket. But now and after replacing the intake and head gaskets and not resolving the coolant in oil issue; and reading about all the cracking issues with pre 01 V10s around the head bolts. I'm suspect one or both of my heads are cracked. All surfaces were straight (within .003) I should have had the heads pressure tested when they were off last, but hind sight is 20/20. But the problem only seems to arise when the engine is up to temp, and the shop was just gonna bench test them with neg vacuum room temp on a bench vs a heated dip tank.
Any ways I'm looking for replacement heads, the newer versions or reengineered designs. I have not seen very many on the internet really. Does anyone have any ideas on where is a good place to source OE or aftermarket (maybe) heads for this engine?
Old 10-23-2013, 03:55 AM
northern2002's Avatar
northern2002 northern2002 is offline
Vehicle: 2002 dodge ram 2500
Trim Level: SLT plus
Color: gray
northern2002 is on a distinguished road
same here looking.
Old 10-24-2013, 01:32 AM
Sledpuller Sledpuller is offline
Vehicle: 1994 Dodge Ram
Trim Level: laramie
Sledpuller is on a distinguished road
I wish there were some better aftermarket heads for our trucks. Unfortunately there aren't any, at least to my knowledge. I don't know if mopar parts has any left in stock.
cracked heads, v10
