tonneaucovered.com
Old 10-22-2013, 09:18 PM
BigT BigT is offline
Vehicle: 2014 Ram 1500
Trim Level: Limited
BigT is on a distinguished road
Default MPG Drop
So I have a 2010 Big Horn and my mpg has been pretty consistent since I bought it new 3 years ago but has dropped in the past month or so. I got new tires a few months ago and Jiffy Lube did my most recent oil change but nothing else has changed as far as I can tell. Anyone else having an issue or any ideas of what's going on? I was averaging about 16 and now I'm down to 14.
Old 10-22-2013, 09:36 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Did JiffyLube use 5W20 in your Hemi? If you're over 30,000 miles, have you changed the plugs? It could be as simple as fuel stations change in blend of fuel too. Just some things throwin out for thought bud.
Old 10-22-2013, 09:54 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Agree with Gantman, if Jiffy put in something other than 5w20 you will find it will not run very well either MDS does not like anything else. As Gantman said, air Filter, plugs, crappy gas, all of these may be a contributor. What kind of tires did you put on.
Old 10-23-2013, 09:49 AM
rockdoc's Avatar
rockdoc rockdoc is offline
Vehicle: 2010 Dodge Laramie Hemi
Color: Grey with silver trim
rockdoc is on a distinguished road
Well there ya go. I have, surprisingly, the opposite happening. Have done nothing new and aside from valve guide seals failure, and as of this A.M. 127,000kms on "Ole Smokey" getting solid 20s' on cruise at 110-120kms per hour?. This on 6 1800+ trips. These trucks confuse me. I did notice mileage increasing slightly with the new plugs at 80,000kms. Good hunting.
Old 10-23-2013, 05:52 PM
Trim Level: Limited
They said they used 5w20 and I made point of it. Also I watched them change the oil and they definitely used what was supposed to be 5w20 but I didn't see the original source. I got Bridgestone - Dueler H/L Alenza tires and I did get the plugs changed at 30k. I've been getting gas at the same stations so that shouldn't be the issue. I might just change the oil myself and see if it changes things. Thanks for the suggestions and keep em coming if anyone else is seeing an mpg drop after 50k miles.
