Old 10-23-2013, 07:38 AM
Walmart Special Walmart Special is offline
Walmart Special is on a distinguished road
Default No power up hills or anywhere!!!
Ok everyone, '06 1500 with the 4.7L. 86,000 miles. Has next to no power, no codes are present. I just put all OEM plugs and Coils on it. If I go to accelerate up a hill, engine revs right up, only gets to about 40-45 mph and then check engine light FLASHES. I stop, wait 15 secs, lights goes out, no codes?? Again, it acts like its only running on 2 cylinders. I need help big time guys an gals!
Old 10-23-2013, 08:54 AM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Have you checked compression? If you punch it how high will the rpm go? More detail.
Old 10-23-2013, 06:26 PM
The engine revs without a problem, it hits damn near 5k or more, but speed wise it won't go more then 40 up a hill, and the engine light will flash the whole time until I let off gas, I have NOT checked compression on cylinders
Old 10-27-2013, 06:24 PM
Bcun10t Bcun10t is offline
Vehicle: 2007 dodge ram
Trim Level: Slt
Bcun10t is on a distinguished road
If you have an Automatic transmission, check your transmission fluid level
Old 10-27-2013, 08:20 PM
transmission level is good. I unplugged the battery and let truck sit for about 15 mins, plugged back in. The truck seemed to run good for about 2-3 mins, then once I hit my first hill and got on the throttle it lost all power (but motor is still revving high) and CEL began to flash again. The CEL did not leave a code for me to read, but the motor feels sluggish and sounds like its skipping. Could this be a computer problem? or a sensor? If it was a sensor shouldnt I be getting a CEL code???
Old 10-28-2013, 07:44 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Did this happen after you changed out the plugs?
Old 10-29-2013, 11:50 PM
Keystone.45 Keystone.45 is offline
Vehicle: 2003 Ram 1500
Keystone.45 is on a distinguished road
You may want to try a new fuel filter. If it's partially clogged, then the engine will get enough gas for light load (or just revving in neutral) but when you want power the plugged-up filter can't flow enough. Just an idea.
Old 10-31-2013, 03:41 PM
HemiLonestar's Avatar
Rep:274
Just keep in mind to do this you will either have to drop the tank or lift the bed, as the filter is integral to the fuel pump inside the tank.
"Big Red"
2006 Charger R/T
Old 08-27-2014, 09:54 PM
gojoego gojoego is offline
Vehicle: 2002 dodge ram 1500 4.7
Color: gray
gojoego is on a distinguished road
have you figured this problem out im having the same probs
