Old 11-21-2013, 09:43 PM
kelmo409 kelmo409 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Deep Cherry Red
kelmo409 is on a distinguished road
Default ipod connection?
hey everyone im new to this site and also new to my truck haha im just wondering if there is a way to play music from an iPod without using the aux port on a 2009 with the touch radio?
Old 11-22-2013, 07:54 AM
dvarn's Avatar
dvarn dvarn is offline
Vehicle: 2009 Dodge Ram 4x4 QC
Color: Stone White
Rep:187
dvarn has a spectacular aura aboutdvarn has a spectacular aura about
Welcome to the forum from a future WY resident. The aux input is the easiest answer. Alternatively, you could put the music on the radio's hard drive. I think it sounds better coming from the hard drive rather than the aux input. There may be aftermarket kits to get a better quality connection, never looked into it though
Old 11-22-2013, 12:30 PM
Lifted Cummins Fanatic
Rep:2036
Does your radio/iPod have Bluetooth? That would be another way...
I have an iPod hooked up to the USB in the upper glove box in my truck and I just leave it there. That way it's always hooked up and I always have music. No need to mess around with plugging something in every time I get in the truck.
Old 11-22-2013, 02:21 PM
Rep:2657
on the 2009 Ram
the Ipod cable was not run to the Upper Glove Compartment, like it was in the newer models
IF you have a radio that had the cable, you had to hunt for it
open your lower glove compartment, then carefully push in the sides of the insert & pull the insert towards you. Then look under the Upper Insert, you will find a screw, remove it, now carefully remove the insert. Then look behind the radio, if your radio came with the cable, it will be coiled up & wire tied to other wiring in back of the radio.
Now is the time to check to see if the radios MINI USB PORT will work with your APPLE device
Some people will put an extension cable on it to run the cable to a better location then the glove compartment for easier use, others just trim out a hole in the glove compartment or run it through the glove compartment lights cut out hole.
I have the 2009 Ram RER 730N radio & my cable was never used & would still be behind the radio.
The RHB 430N & RBZ 430 radios should have come with the mini usb cable
I don't recall if the RES 130 & RES 130s radios came with a mini usb cable
Old 11-22-2013, 03:59 PM
dvarn's Avatar
Color: Stone White
Rep:187
GT, I was hoping you would post on this thread. I'm going to look into that on my own truck. Thanks
Old 11-26-2013, 08:32 PM
Sudsand Sudsand is offline
Vehicle: 2009 Ram 1500 Laramie Crew
Sudsand is on a distinguished road
How do I know if my 2009 is supposed to have the iPod cable?
Thanks,
Mike
ipod, ipod integration
