going to use Homelink buttons to turn on pov lights. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - SIGS - Special Interest Groups > Public Safety
Public Safety Special Interest Group for Police/Law Enforcement, Fire, and EMS Personnel! - Click the badge to the right to request membership>>
Old 10-23-2013, 10:01 PM
chrisnarron chrisnarron is offline
Vehicle: 2009 dodge ram 1500
Color: gray
Rep:59
chrisnarron will become famous soon enough
Default going to use Homelink buttons to turn on pov lights.
i just got a 2009 ram. i had a 04' previously lit up like a Christmas tree. wiring is a big hobby of mine. but im always posed of where i can put a clean looking switch. well when i got this truck i knew what i wanted to do. i wanted to find a way to use my factory Home link garage door buttons to toggle a relay and turn my lights on and off. today i tested this theory on a light bar out side the truck and it worked. i purchased a linear wireless receiver and 3 wireless buttons. programmed each button on its on Chanel on the receiver and then each receiver to its respective home link button. i just broke negative power of my light with the relay. it worked perfectly. so now i have three buttons that wireless give me a dry contact. now to buy lights im either going to make switch one control the front, 2 the rear and three the sides or do 1 the front and sides, 2 the rear and 3 all the lights.
Has anyone done or seen this done before?
Old 10-29-2013, 12:24 PM
tlvzee tlvzee is offline
Vehicle: 2002 Dodge Ram 1500
tlvzee is on a distinguished road
That is one heck of an idea!! I like it, but I'm afraid with my meager electrical skills, I can't help you with any ideas. I've got a 2002 third gen. Ram that I've been looking for ideas to run emergency lighting with clean looking switches. I do also have the homelink system, but never thought of trying to run lighting from it. I have 2 dummy switches next to the front heated seat switches. So far, I haven't been able to find a factory style switch that fits in that particular panel. I'd love to here any good ideas you had with your previous truck. Good luck with your '09! Please let us know how your install turns out.
Old 11-22-2013, 02:19 PM
Firemedic10584 Firemedic10584 is offline
Vehicle: 2016 Ram 1500
Trim Level: Sport 4x4
Rep:163
Firemedic10584 has a spectacular aura aboutFiremedic10584 has a spectacular aura about
heck of an idea!! I did a basic setup in my 2011...but in this 2013, I went with less lights and a switch that looks like it came in my truck from the factory. I have a Ram specific Feniex pegasus up front, two T-6s on the toolbox for the sides, and two T-6s on a license plate bracket for the rear. The Pegasus I couldn't say enough good things about. The fitment against our windshield and headliner is amazing!
Old 11-22-2013, 02:30 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
You sir are insane in theory. I've never tried it now I have a new challenge this site needs a hazard warning on it because every time I get on it it becomes bad for my wallet.
Great find
Old 11-22-2013, 02:32 PM
Rep:2929
When my garage door was made out of wood & had the garage door opener
i just put a micro switch to turn on the lights in the garage, when ever the door was opened, the light stayed on for 5 minutes. By that time i could get out of the vehicle & turn on my overhead shop lights
Now my garage door is made out of aluminum & runs on a track along the ceiling
i am thinking about using a different micro switch to place along the track, to do the same thing
Old 12-05-2013, 08:33 AM
Color: gray
Rep:59
I did the set up in my 2009 and my buddys 07 ram. It works flawlessly. The 07 truck you have to hold the home link button down for .5 seconds where as mine is instant. I just used a 4 channel wirelss receiver so I could have 3 different outputs for each home link button. I had to use 3 different 315 mhz remites to program the receiver and homelink transmitter. The wireless reciever provides me a dry contavt on each chanel when activated by home link. I used each contact to break negative power on 3 30 amp relays. So when I hit a home link button it sends a signal to my receiver. My reciever then then buts a short on my relay negative piwer. The relay has constant dused 12v positive. The relay turns on and my lights come on. I have a relay for front rear and side lights. I will be tring to up load pics as I can. Maybey even do a formal writw up.
Old 12-05-2013, 09:44 AM
Iqudayo's Avatar
Rep:563
I would love to see how you did this I can use (borrow) your idea I have lights to hook up and no other good spots, I can use that spot to run my emergency lights (blue lights) it's not a switch that is easy to reach possibly for my air horn. please give us details you have a great idea at hand
Old 12-10-2013, 09:12 PM
Color: gray
Rep:59
Heres a few pics of my set up. the top piece is the wireless receiver that communicates with the homelink. more or less you program it just like a garage door receiver. i then use the out puts to power the two relays below. i do that by giving the relays positive 12v from my fuse panel. i then break the ground with the out put from the receiver. when it powers up it switches the states of my relays. i use the relays to break the power of my lights. one relay is for front lights and one for the rear. i dont have good pics of the rear but all together the rear has two light bars in the window. 4 hideaway leds in the tail lights, two lights on the reciever hitch and 4 micro leds under the tailgate. i used the sho-me flasher pictured for some of the leds.
Old 12-17-2013, 01:32 AM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
holy shit... Thats crazy fantastic..
Green Interior LEDs
Old 12-17-2013, 04:43 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Crazy fantastic... can't argue with that. Nice set up, Dood!
