Old 01-24-2014, 03:14 PM
PJAvenger's Avatar
PJAvenger PJAvenger is offline
Vehicle: 2013 RAM 1500
Rep:41
PJAvenger is on a distinguished road
Hi there, I'd like to feel re-assured about a winter tire package. I have a 2013 Sport 4x4, stock 20" wheels and 275/60R20 tires, stock suspension.
For winters, I'm looking at 17x7.5 wheels and 265/70R17 Michelin X-Ice.
That's from an SXT truck as per your typical fill-in-the-blanks tire site.
Would be fine for Sport?
Old 01-24-2014, 03:33 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Yes it will work no problem. Your speedometer and odometer will be off though because of the tire size. You will actually be going slower than your speedometer says and driving a shorter distance than what your odometer says.
Old 01-24-2014, 03:36 PM
PJAvenger's Avatar
Rep:41
Thanks! Guess I will just have to drive faster
Old 01-25-2014, 05:07 AM
llleonard4's Avatar
llleonard4 llleonard4 is offline
Vehicle: 2012 Dodge Ram
Trim Level: st
Color: silver
llleonard4 is on a distinguished road
i am in need of new tires...i am not happy with factory tires...i've had my ram just a little over a year and a half now with almost 38000 miles on her. what would be a good tire to put on her? im in guam and it rains a lot from jan- about july so ive been told. and the roads are made with coral so when it rains they are slick.
2012 ram 1500 st mods include k&n filter, rod rack, tool box, and cb
Old 01-25-2014, 11:36 AM
Ranman's Avatar
Ranman Ranman is offline
Vehicle: 2014 Dodge Ram
Rep:120
Ranman will become famous soon enoughRanman will become famous soon enough
Default 275 65 17
Hey gang, I currently have stock 17 inch wheels/tires on my Ram. They are 265 70 17. Will 275 65 17 tires fit on my rims? Will I have any issues?
MODS: Front window tint to match rear, Extang tri fold soft tonneau cover. Dee Zee running boards. Tinted tails and 3rd brake light. Blacked emblem and de-badged. Drop in K&N filter. 2.5 inch Hell Bent Steel leveling kit. Cabin air filter. Upper glove box. Magnaflow exhaust. Black bull bar with 20" Cree LED bar. Mickey Thompson 35x12.5x20 MTZ's
Old 01-25-2014, 11:41 AM
Ranman's Avatar
Rep:120
Default 325/60/20 ??
Would these fit on 20 inch stock chrome clad rims? Would they fit on a 2014 Levelled only Ram?
Old 01-25-2014, 05:09 PM
knucklebucket knucklebucket is offline
Vehicle: 2003 ram 1500 quad 4x4
knucklebucket is on a distinguished road
okay guys, new to the whole custom thing. I am wanting some new wheels and tires on my 03 ram 4x4 1500 quad cab. I am going to put a leveling kit on it, I don't want to really raise it a whole lot but would like a beefier look. please give me some suggestions and ideas pertaining to sizes and dealers.
Old 01-27-2014, 02:40 PM
Rep:2036
I would recommend a good AT tire. Toyo AT2's or Nitto Terra Grapplers are both very popular choices. Are you looking to stick with a stock size or are you wanting to go larger?
275/65/17's are shorter than your stock 265/70/17's.... so yes they'll fit no problem. I'm just wondering why you'd even want to do that. The stock tires are already short enough, why go smaller?
I'm not sure what you're referring to here....
For an 03 you don't need to buy a leveling kit. Just crank up your torsion bars to lift the front end of your truck approximately 2 inches. You might want to buy longer shocks to avoid having them bottom out when your suspension drops. But they may not be necessary. You'll also want to get an alignment done after you crank them up.
As far as tires go it really depends on what you want to do. Are you planning to run stock wheels or aftermarket? What kind of tires do you want to run? Those are two key pieces of information that will really influence what we recommend for you.
Old 01-28-2014, 12:05 PM
calvinmx48 calvinmx48 is offline
Vehicle: 2014 sport CC
Trim Level: sport
Rep:16
calvinmx48 is on a distinguished road
Default Ultra 198 B
Looking at a specific rim after months of looking.
It's made by ultra and model is 198B
20x10 -6 offset
I have a 14' ram sport on bilsteins maxed out and a TGC 1" spacer in the back
I also have 2500/3500 oem flares. How much will this rim and tire combo stick out ???
I will be running a 295/60/20 trail grappler
Also call bully's get me this wheel ??
Thanks
CAle
Hemi fever tuned Trinity, bilsteins @ 2.8, 1" TGC spacer, LMI SRI, 180 T-stat, 2500/3500 flares, weather techs, heart-throbe muffler kit, BT catch can, 5K HIDs, on the way- black rhino glamis wheels wrapped in nitto trails
Old 01-28-2014, 07:29 PM
Rep:2036
20x10 -6 offset
Thanks
CAle
With that set up you'll be fairly flush with your flare. The tread should be tucked under it completely but the bulge will stick out slightly past.
Send Bully's an email at sales@bullysperformance.com and let them know you're a forum member and what you're looking for. They'll get you going from there.
