Old 01-28-2014, 09:24 PM
calvinmx48 calvinmx48 is offline
Vehicle: 2014 sport CC
Trim Level: sport
Rep:16
calvinmx48 is on a distinguished road
Default Okay
Thanks Brandon. Yes I have bought some stuff from Andrew so I will shoot him an email
Hemi fever tuned Trinity, bilsteins @ 2.8, 1" TGC spacer, LMI SRI, 180 T-stat, 2500/3500 flares, weather techs, heart-throbe muffler kit, BT catch can, 5K HIDs, on the way- black rhino glamis wheels wrapped in nitto trails
Old 01-30-2014, 10:44 AM
finn5033's Avatar
finn5033 finn5033 is online now
Vehicle: 2014 Ram 1500 cc 4x4
Trim Level: Outdoorsman
Color: Granite
Rep:32
finn5033 is on a distinguished road
I have a question about wheels for the outdoorsman/Laramie models with the fender flares. I would like to get a set of stock size 20" wheels and tires for my summer wheels. What offset would I need for that? I don't want the wheels and tires to look set inside the wheel wells. Is it a different offset than the stock ram wheels on the models without the flares?
Old 01-30-2014, 12:06 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Stock Laramie wheels are 20x9 +19 offset. Doesn't matter if they have flares or not. Are you looking to run stock size tires as well?
Old 01-30-2014, 12:34 PM
finn5033's Avatar
Color: Granite
Rep:32
yes stock size A/T tires. Don't the Fender flares stick out farther than the trucks without flares?
Old 01-30-2014, 12:50 PM
Rep:2036
Okay you'll be fine with the stock wheels then.
The lower trim trucks with out flares that come with the 17" wheels don't stick out quite as far. But the 20" wheels for the Sports or Laramie's are all 20x9 +19 offset. Doesn't matter if they have flares or not.
Old 01-30-2014, 02:13 PM
finn5033's Avatar
Color: Granite
Rep:32
Ok I guess I'm not asking this right. I want the tires to be at least flush or stick out a hair from the flares. Do i need a different offset to accomplish that? Also I assume you guys sell wheels and tires, I couldn't find them on your website?
Old 01-30-2014, 02:20 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
To be flush or stick out past the fender flares you will need a smaller offset than +19mm.
Thanks
Old 01-30-2014, 02:27 PM
Rep:2036
Okay... I was thinking you were asking if Ram put different wheels on from the factory depending on the truck having flares or not...
If you want to be flush with the flares you will need a smaller offset as Eric said. What wheel and tire set up are you running now and how far are they tucked under the flares? And what's the exact tire size you plan on running on the 20's?
Old 01-30-2014, 03:44 PM
finn5033's Avatar
Color: Granite
Rep:32
My truck is on order, I should be getting it in about 3 weeks. Its the outdoorsman model and comes stock with the 17" wheels and goodyear A/T tires. I would like to run 20x9's with stock size 275-60-20 A/T tires.
Old 01-30-2014, 04:28 PM
Rep:2036
I would probably go with a +12 offset wheel if they make it in the wheel you want. That should put you fairly flush with the flares.
DAA is running 275/60/20's on his stock 20x9 rims. He doesn't have a picture showing exactly how far his tires stick out but here's his thread with a few other pictures - http://www.ramforumz.com/showthread.php?t=151853&page=2. I would post up in there asking him to get a shot down the side of the truck showing how far his tires are tucked under. That will give you a good idea.
