Old 02-19-2014, 09:13 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
How wide of a wheel? You didn't give any dimensions.....20x12 I'm assuming?
Old 02-19-2014, 09:26 PM
Blue Rig's Avatar
Blue Rig Blue Rig is offline
Vehicle: 2010 Ram 1500
Color: Blue
Blue Rig is on a distinguished road
Default Brandon
Thank you for the info! Would have PM you but not enough posts!
Old 02-21-2014, 01:32 AM
DRam14 DRam14 is offline
Vehicle: 2014 Dodge Ram 1500 4x4
DRam14 is on a distinguished road
I made a thread and then i saw your post....so here goes. Im going to get the Bilstein's and set them at the 2.1 setting. The only thing is, they wont be available for a month or so. How bad would it rub if I put some nitto trail grapplers(295/60/20) on my stock wheels before the leveling kit gets here? Will I be able to drive around like that, or will it rub to bad? Thanks.
Old 02-21-2014, 02:20 AM
Rep:2067
I would be waiting until you get the Bilsteins installed. You could probably make the 295/60's fit but it's going to take quite a bit of trimming and messing around to make it work. Not worth your time if you're just going to level it in a month any way.
Old 02-21-2014, 12:42 PM
Thanks for the reply Brandon. I figured that was going to be the best way. These stock tires are killing me though, and i just can't wait to get a mud tire on there. I know it's doing things a little backwards, but if someone else has done it and it didn't require major mods to be able to limp around for a month..then I'd probable take the backwards route.
Old 02-21-2014, 02:23 PM
I've always assumed i had 20x9"s on my truck, but looking at the sticky above, it seems i may have 20x8"s. In this case, the sticky said that 290/60/20's should fit. I've never been big on spacers, but it seems the 1/4" hub centric ones(without lugs) is very safe. Any thoughts on this knowing my wheels may be 20x8's, or thoughts on the safety of a 1/4" hub centric Bora spacer?
Old 02-21-2014, 02:42 PM
Rep:2067
Typically the widest you can fit on stock wheels is 285's. There are guys that have fit wider tires but it's iffy. I would have spacers ready in case you need them. There shouldn't be any issues with running a 1/4" hub centric spacer.
Old 02-21-2014, 05:49 PM
WIexpress WIexpress is offline
Vehicle: 2012 Ram
Rep:57
WIexpress will become famous soon enough
I know this has probably been answered but couldn't find a def. answer. What is the weight on the 20" Aluminum sport wheels that come on the 4th gens
Old 02-27-2014, 09:34 AM
pitt gsxr's Avatar
pitt gsxr pitt gsxr is offline
Vehicle: 2011 Dodge Ram
Color: Blue
Rep:25
pitt gsxr is on a distinguished road
In a effort to save money and increase the WAF factor of my truck I'm trying to keep my stock 17's and get some new beefier tires. I'm looking at the Toyo AT II LT 285/75/17.
My question is: this tire says it should be mounted on a 7.5-(8.0)-9.5 wheel. My stock 17's are 7" wide i believe... how big of a problem is this? Am i risking sidewall damage by having too narrow of a wheel? Are they going to wear unevenly/differently than they should?
Cory 2011 Quad Cab LT 4x4 Mods: Viper 5901 Alarm/Remote Start, Custom center console with eD 13av.2 on a Nine.1, Debadged
Old 02-27-2014, 11:10 AM
SShadow1974's Avatar
Vehicle: 2016 Ram 1500 Sport w/RAMBox
Rep:166
Not thread jacking, but do you have a URL for those tires? That's the size I'll be looking for once I wear this GYs down.
S S H A D O W
