Do you have questions about wheels, tires, etc post them up we will answer :) - Page 19 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-02-2014, 10:22 PM
Brian95 Brian95 is offline
Vehicle: 2013
Trim Level: Quad cab , sport
Brian95 is on a distinguished road
2013 1500 quad sport 4wd. I want to run 35/12.5r20. What width and offset 20" rim should I run without rubbing. Stock fenders with no flares. I know they are going to stick out a little but I'd like as flush as possible without rubbing the inner spindle. Also thinking about 4" mopar lift with bilstiens.
Who is running toyo oc mt's. How loud are they.
Thanks
Old 03-02-2014, 10:58 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Thanks
If you want to stay as close to flush as possible and have the least chance of rubbing you'll want a 20x9 0 offset. They'll be sticking out approximately 1.5" past your fender (to the outside of the budge). If you put a 4" lift on down the road you will want at least that wide of a stance to make it look right.
The Toyo MT's are surprisingly quiet for a mud tire. I was very impressed with mine.
Old 03-02-2014, 11:13 PM
tnhemi tnhemi is offline
Vehicle: 2012 Dodge Ram 1500 Express
Color: Grey
tnhemi is on a distinguished road
2012 1500 Quad Express 4x4 with factory 20's. I want to level the front. What is your thoughts on how I should go? Bilsteins? I am asking cause my Crapyear's are about toast at 20k so I need new tires. What is the biggest tire I can fit with truck leveled? I will be pulling a camper and what E rated tires.
Old 03-02-2014, 11:15 PM
Moderator
Rep:2140
Check out the Guide to Leveling & Wheel and Tire sizing linked in my signature. It will answer all your questions.
Old 03-03-2014, 01:28 PM
finn5033's Avatar
finn5033 finn5033 is offline
Vehicle: 2013 Ram 1500 cc 4x4
Rep:32
finn5033 is on a distinguished road
You'll be tucked under them by approximately a 1/2" with that set up.
I'm not sure if this makes a difference or not but my factory wheels are 17X7. So I will gain an 1" with the 20X9 wheel right off the bat. From what I've found stock ram 17's have a +25 offset so with the +14 offset will get me almost a 1/2". So maybe I need to go with a 0 offset then to get that last 1/2"
Old 03-03-2014, 02:29 PM
Moderator
Rep:2140
Yup, I would go with a 0 offset to be flush with a 275 wide tire.
Old 03-06-2014, 04:55 PM
MeanieNJ MeanieNJ is offline
Vehicle: 2013 Ram
MeanieNJ is on a distinguished road
Im at stock height. No level or anything. I want to just get rims with a little wider tire but keep the stock tire height. What is the widest I can go without any rubbing? I was thinking a 20x9 wheel but Im not sure what offset I should go with. I don't the tires barely poking out but at stock height I don't want it to look like a rollerskate either.
Old 03-06-2014, 05:15 PM
Moderator
Rep:2140
Well you've left it fairly open as to what you could run. How much wider of a tire do you want to run? Really I'd recommend a wheel with stock specs (20x9 +19 offset) and then a 285/60/20 tire. That's give you the slightly wider tire without too much poke and will work at stock height.
Old 03-07-2014, 05:16 AM
Vehicle: 2013 Ram
That was supposed to say I don't MIND the tires poking out a little lol. As far as tire width, the wider the better. If I can fit a 305 in there somehow without rubbing issues and without them sticking out way too far I will lol. Im guessing that's not the case though.
Old 03-07-2014, 01:12 PM
Moderator
Rep:2140
Okay, well that will be very possible. If you go with something like a +12 or 0 offset you'll fit that wide of a tire no problem. If you went with a 20x9 +12 offset wheel with a 305/55/20 (33.2x12) tire you'd be sticking out past the fender about 3/4". Maybe a little less depending on the type of tire you go with.
