Old 03-07-2014, 01:02 PM
MeanieNJ MeanieNJ is offline
Vehicle: 2013 Ram
MeanieNJ is on a distinguished road
That's not bad. That's probably what ill go with then. Thanks.
Old 03-07-2014, 01:04 PM
Vehicle: 2013 Ram
double post
Old 03-07-2014, 08:04 PM
obxram obxram is offline
Vehicle: 2010 ram 1500 trx4
Trim Level: trx4
Color: gray two tone
obxram is on a distinguished road
Default my questions please
ok here is my plan lets see what will work
bilstiens for the leveling
wheels eagle alloy series 016 18x10 -24
here are my tire options
toyo atII 325/60 18
toyo atII 35x12.5 18
toyo atII 295/70 18
whats the opinions please
Old 03-07-2014, 10:39 PM
nboake23 nboake23 is offline
Vehicle: 2013
Trim Level: Outdoorsman
Color: True Blue Pearlecent
nboake23 is on a distinguished road
2013 dodge 1500 stock height stock wheels, want to put 20x12.5 fuel octane deep lip off-road on with 33x12.5R20 rubber, Im assuming I would require a lift to fit the wide wheel? how high, would it even work , if not whats the widest wheel others have run with a 6in lift
Old 03-08-2014, 01:46 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
toyo atII 325/60 18
toyo atII 295/70 18
The 35x12.5's for sure. Even with those you are going to need to do some trimming because of the width and offset of the rim you want. But it's definitely possible.
Old 03-11-2014, 07:52 PM
powerlftr201 powerlftr201 is offline
Vehicle: 2013 Ram 1500 Big Horn
powerlftr201 is on a distinguished road
Default questions about hell bent steel 2.5" leveling kit for 2013 ram 1500 big horn
I have been considering the HBS 2.5" leveling spacers for my 2013 Ram, I was just curious if it was recommended or necessary to get a front end alignment after installation. I would venture to guess that it would be but just want to be sure. Thank you
Old 03-11-2014, 07:55 PM
Rep:2036
Yes, definitely. Any time you change anything on the front suspension of a vehicle it will need an alignment.
Old 03-11-2014, 09:33 PM
Ordy's Avatar
Ordy Ordy is offline
Vehicle: 2014 Ram 1500 4x4 Long Bed
Trim Level: Longhorn
Color: Two Tone Black Gold Pearlcoat
Ordy is on a distinguished road
I have a tire question. I have a 2014 Longhorn 4x4 with 4 corner Air Suspension on order. The truck comes with P275/60/R20 Goodyears. I read a bit and asked the dealerships service manager if Toyo Open Country ATII that were LT275/65/R20 would fit on my truck. He said "Yes. I can go one size higher than stock and it will be fine". The rep at Tread Depot said "No. They won't fit unless you have a lift kit on the truck." Who is right in this scenario. I ordered the tires anyway so I am a little nervous about the truck with the Air Suspension and the new tires. Anyone have any insight on this setup?
Thanks,
Ordy
Old 03-11-2014, 10:33 PM
Rep:1797
Originally Posted by ScoMo View Post
I am looking to buy new wheels and tires for my 13 w/ air suspension. Not sure what kind of aftermarket setups people have been running so far without rubbing. I read on another thread that someone is running 305 toyo at's on 20" fuel wheels with only minimal rubbing in E/E mode. Hard to believe since there is minor rubbing at normal ride height with factory wheels/tires already. Maybe something that like is possible with spacers or offset? Anyways, just wondering what specs I need to look for to make something work without rubbing issues. I want to keep a 20" wheel and use toyo at2's if possible. Hoping not to go the spacer route either.
bump for some help please..
Alignment is recommended
Old 03-12-2014, 07:19 AM
lowfast lowfast is offline
Vehicle: 2014 Ram 1500 CC 4x4
Trim Level: 1500 Longhorn 4x4
Color: Western Brown Monotone
Rep:92
lowfast will become famous soon enough
Thanks,
Ordy
You will be fine
2014 Ram Longhorn CC 4x4 - Born 01/10/14, Western Brown, HEMI, 3.92, LS, AMP PowerSteps, Rancho RS9000 QuickLift and 275/65-20 DynaPro ATMs
2010 Lexus IS-F - Joe-Z Intake
1965 Ford Falcon Hardtop - ProTouring Monster in Progress, 4.6 V8, TCI Suspension, 18x8 & 18x11 Team III Wheels
