Do you have questions about wheels, tires, etc post them up we will answer :) - Page 21 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-12-2014, 08:54 AM
Ordy's Avatar
Ordy Ordy is offline
Vehicle: 2014 Ram 1500 4x4 Long Bed
Trim Level: Longhorn
Color: Two Tone Black Gold Pearlcoat
Ordy is on a distinguished road
Thanks Lowfast. I was a little worried about the Air Suspensions Entry/Exit Mode with the new Toyos. If I am in that mode in a parking spot and need to do some full cut turning to get out I didn't know if the tires would start rubbing and tearing things up.
Old 03-12-2014, 09:19 AM
lowfast lowfast is offline
Vehicle: 2014 Ram 1500 CC 4x4
Trim Level: 1500 Longhorn 4x4
Color: Western Brown Monotone
Rep:92
lowfast will become famous soon enough
I think the only rubbing anyone has had with Air Suspension and that tire size is a small plastic screw/plug in the wheel well that sticks out and it will only rub at entry height. I do not think it will harm the tires. The solution has been to either remove, file down that protrusion or just let the tires "take care of it" over time. Even so i would think you are not supposed to drive at all at entry/exit height, even parking, so it should not be an issue.
2014 Ram Longhorn CC 4x4 - Born 01/10/14, Western Brown, HEMI, 3.92, LS, AMP PowerSteps, Rancho RS9000 QuickLift and 275/65-20 DynaPro ATMs
2010 Lexus IS-F - Joe-Z Intake
1965 Ford Falcon Hardtop - ProTouring Monster in Progress, 4.6 V8, TCI Suspension, 18x8 & 18x11 Team III Wheels
Old 03-12-2014, 10:32 AM
SShadow1974's Avatar
Vehicle: 2016 Ram 1500 Sport w/RAMBox
Rep:166
Just thought I would confirm that the stock 17" aluminum wheels on the Outdoorsman offset is +25mm and are 7" wide, as opposed to the 8" in the original topic. I checked today while the truck was on the hoist for an oil change.
S S H A D O W
Old 03-12-2014, 12:26 PM
seananderson54 seananderson54 is offline
Vehicle: 2003 Dodge Ram 1500
Color: Gold
seananderson54 is on a distinguished road
Default Aluminum Alloy Finish Cracking
I have a set of OEM 20" aluminum alloy wheels that came with my truck (2003 1500). The finish has started to crack on the surface (not structural) . I was wondering if anyone has experienced this and is there a possible way to fix this? Sorry if this has been posted before, I don't have time to read 20+ pages of replies.
Old 03-12-2014, 03:09 PM
maxjerome28 maxjerome28 is offline
Vehicle: 2008 Dodge Ram Quad Cab 4X4
Trim Level: st
Rep:16
maxjerome28 is on a distinguished road
I've got an 08 with 20s and the "chrome" is peeling in spots as well. :-/
I fixed this with plastidip... Ok he didn't fix it but it looks way better.
Old 03-13-2014, 09:39 PM
obxram obxram is offline
Vehicle: 2010 ram 1500 trx4
Trim Level: trx4
Color: gray two tone
obxram is on a distinguished road
ok found the rims i want now need help with the tires
rims are 20x10 -24
what tires can i run with little to no rubbing with bilstiens
i am not looking for a 13 wide tire either
thanks in advance
Old 03-14-2014, 10:04 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
rims are 20x10 -24
thanks in advance
What tire height are you looking to run? Im assuming a 35"?
You will rub regardless due to the lack of height and how negative the rims are.
Many run this on the board and will require trimming/modification to get it to fit.
Nothing to difficult a dremel can't fix
sales@revelperformance.com
Old 03-14-2014, 12:25 PM
Trim Level: trx4
I am looking to be between 33 and 34 in height
Old 03-14-2014, 12:28 PM
Revel Performance
Rep:1804
With a 33" you will be ok and more than likely the same with the 34"
However, if there is rub on the 34" it will be slight, and again something that can be corrected.
Old 03-14-2014, 12:31 PM
Trim Level: trx4
Is there a thread or pics of what you are talking about?
