Old 03-16-2014, 12:25 AM
seppie10 seppie10 is offline
Vehicle: 2010 Dodge Ram 1500 Trx4
Trim Level: TRX4
Color: INFERNO RED/GRAY
Rep:19
seppie10 is on a distinguished road
I have about 6 inches to play with on my stock truck to fit into the garage. I will be adding the blistens up front and rear and either run 2.1 or 2.8 up front. My question to you is I would like to run level to the outside of my fender flare which is stock on a trx 4 package. What would u recommend for this type of wheel and tire size package? I am having a hard time figuring to go with a black wheel or chrome. I do have chrome step tubes and colored gray bumpers and black bug shield and window vents. I really enjoyed the the pics of the orange truck with the black wheels on It but he had the 2.5 kit on it. I hope I didn't make this difficult for you lol. I also liked the white ram with the blistens on it and chrome wheels and size 35's on 20 wheels but I don't what to go with 20's as far as cost's goes. Thank you and hope you can give a lil advice
seppie
Old 03-16-2014, 05:17 AM
2005DodgeRamHemi's Avatar
2005DodgeRamHemi 2005DodgeRamHemi is offline
Vehicle: 2005 Dodge Ram 1500
Color: Grey
2005DodgeRamHemi is on a distinguished road
I have an 05 1500 and I want to put on larger tires and wheels that stick out just a little bit... perhaps an inch. Would that mean that I need a 4.5" backspace? I saw somewhere the stock wheels were 5.5" backspace - but I'm not sure.... so I want to find a wheel that will stick out an inch or so, and put the largest tire on without rubbing. I don't want to mess with lifting it... any advice?
Old 03-16-2014, 10:59 AM
Rep:1804
You'll want a 9" wide rim with a 0 or +1 offset
Old 03-21-2014, 12:46 AM
Miouo Miouo is offline
Vehicle: 2014 Ram 1500
Miouo is on a distinguished road
Couple questions:
What type of mileage difference, if any, do you think I'll see between GY Duratracs and a GY Silent Armour or GY All Terrain Adventure with Kevlar?
I do mainly city driving, highway on weekends, and with my work position changing now, less and less off-road. Our winters can be a nightmare, so I want good winter rating also. As you can tell, I may be moving away from a more aggressive tire (although I will miss the look).
What tire do you recommend (stock: 275/60R20)?
Old 03-23-2014, 01:19 AM
BlueRam2014 BlueRam2014 is offline
Vehicle: 2014 Ram 1500 Big Horn
Color: True Blue Pearl
BlueRam2014 is on a distinguished road
What is the best way to clean and maintain the shine on my 2014 RAM Chrome Clad 20" wheels? What products should I wash them with to avoid scratching or dulling them and then what products are best to keep them polished up?
Old 03-24-2014, 05:11 PM
817moto's Avatar
817moto 817moto is offline
Vehicle: 2002 Dodge Ram
817moto is on a distinguished road
Hi, new to the forum and looking for some advice or guidance. I drive a 2002 ram 1500 QC 4x4 sport. I plan on going with a rough country 5" lift and need advice regarding rims and tires.*
I'm pretty much set on moto metal 961 rims going down from my stock 20's to 18's. I want to get the deep look of the rims and if I am correct I want a negative offset. The 18's are 18x10 for -24 offset and +18 for 18x9. Tires wise I'm looking at either 35" or 37".
My concern is with 37's similar to the person asking on page 5 of this thread, is my gearing going to need changing to compensate for the heavier 37" tires?if I go with 35's are they going to look weird?*
Obviously I want it to look good and sticking out past flush is welcomed. With the bigger tires I know it will stick out more but they aren't a whole lot more money than the smaller choice. Can anyone give me suggestions as to the lightest 37's as I have a 5.9v8 and the fuel mileage is already bad enough lol.
My other concern is with a 5" lift will the large negative offset cause rubbing with 37's? I know they will have no problem with the suspension but the body becomes a factor when they are pushed out that much. *
When I'm looking for 37" m/t tires online, All I can really find are trail grapplers, mud grapplers and open country. I did see fuel makes tires as well but would rather use a more reputable brand that specializes in tires. I know the toyo's are ultra heavy so I would rather not unless someone can assure me my gearing is ok (I just had a complete tranny rebuild and would rather not have to do it again. My wallet would apprecite it).
Should I go with The 35" tires wil be Cooper discoverer stt as they are pretty light, decent reviews and made in the USA.*
I would obviously like to have some that last a long time. Truck is my daily but I do enjoy playing in the mud. But I would say prolly 75/25 split of on road and off road. *
If someone can help me I would greatly apprecite it. After reading all of the pages in this thread, I apologize for the lengthy post but I found very little with regards to my questions. I notice Brandon seems to know his stuff extreamly well and hopefully he can help me out as well as he did everyone else. *
Thanks. **
Old 03-24-2014, 05:37 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2051
Originally Posted by Miouo View Post
Couple questions:
Tire size and weight will affect your mileage the most. Once you get into All Terrain tires they are typically heavier so you will notice a bit of a loss. But without knowing the size you're wanting to go with it's hard to give you any estimate of loss. It shouldn't be anymore than 1 mpg if you're sticking with a close to stock size.
You're better off asking that question in the washing and waxing section of the forum HERE. Although I'm sure the subject has been covered many times so if you just browse through that section or use the search function on the forum you'll find what you're looking for.
Thanks. **
For a deeper rim you'll want an 18x10 for sure. The negative offset only pushes the rim out further, it doesn't actually make the lip any deeper (on most wheels at least). Only the width of the wheel changes the depth of the lip.
I'm not quite as knowledgable with the 2nd gen stuff as I am with the 3rd and 4th gen stuff so I honestly can't give you an exact answer about running 37's and if they'll rub. With only 5" of lift and a 18x10 -24 offset rim my gut tells me they would.... however I do know that the 2nd gens do sit a bit higher. So it may be possible. I know on a 4th gen 2500 you can fit 37's with the 5" RCX lift so if the overall height is similar on a 2nd gen I could see it working.... Hopefully someone who knows 2nd gens a little more will chime in for you.
You can't go wrong with the Toyo MT's or Nitto Trail Grapplers. Both perform very well both on and offroad, you won't be disappointed with them in either 35's or 37's.
Old 03-24-2014, 06:32 PM
Geniusgene's Avatar
Geniusgene Geniusgene is offline
Vehicle: 2010 Ram 1500 QC
Color: Inferno red pearl
Geniusgene is on a distinguished road
didnt see much on pure street tires. i have stock sport 20x9 chrome clads and was wondering the prefered street only tire, may go to 22's if i can find a exact copy of the stock 5 stars. i never go off road and avoid snow driving if possible. i realize this isnt a common request but im starting to think im the only one with only street performance tire questions. my quads are for off road, not my sport. thanks.
BT catch can, Borla pro xs, Afe drop in filter.
Old 03-24-2014, 10:37 PM
817moto's Avatar
Thanks Brandon for the quick reply. I don't have an pictures of my truck but I'm sure you know 02 was a split year, and well I got the second half I guess so I'm a 3rd gen! thanks for the rim info I will be going with those when I get the cash. Can you re-advise me now you know I'm a 3rd gen? Haha I will get pics but I'm ashamed of the box and cab corners. As you know the Canadian winter roads are our trucks kryptonite. Thanks again man, I can see me coming to you more often!
Edit: I also read somehwere that your backspacing has to compensate for your lift or something along those lines. Any truth to this? If so what am I looking for?
Thanks.
Old 03-25-2014, 12:54 PM
Rep:2051
I don't have a ton of info on pure street tires as I haven't dealt with them on a truck. Typically most guys are running at least AT tires. I have always been a fan of Toyo Tires though and have been very impressed by the ones I've ran. The Toyo Proxes STII's are a good looking street tire and from the specs Toyo's shows I think they would work pretty good. I can't comment on real world experience with them though.
Thanks.
Okay well if you have the 3rd gen body style then you definitely aren't fitting 37's on those rims with only 5" of lift. So I'd recommend sticking with 35's.
The backspacing doesn't need to compensate for the lift... but most lifts have a maximum backspacing that you can run to still clear their components. On the Rough Country 5" kit that's 5.5". An 18x10 -24 offset rim has 4.5" of backspacing so you're good to go there.
