Old 03-25-2014, 01:39 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:749
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
geniusgene, i also live in north jersey, i am still running the stock gy, but on my wifes grand cherokee i put on a set yokohama. an all weather tire. have about 10000 miles on them and they are wearing fine and handled this winter and year round driving just fine.
Old 03-26-2014, 03:32 PM
DestroyerzCT DestroyerzCT is offline
Vehicle: 2014 Ram Sport 4x4
Color: True Blue
DestroyerzCT is on a distinguished road
All,
I have a new 2014 Sport 4x4 Crew Cab 6.4 bed and Air Suspension. I need to ditch the OEM tires ASAP. They have me stuck in forest every time I need to fill my 200gal tank with maple sap...errrrr.
That said I'd like to go with General AT2's LT35/12.50R20 tires on the OEM rims. I know I will need to change the offset but not sure to what offset (thinking zero) and what else will need to be done or can be done with the Air Suspension to accommodate the 35in tires.
Any ideas or advice would be GREATLY appreciated!!!
Thanks!
Old 03-26-2014, 04:05 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Originally Posted by DestroyerzCT View Post
All,
Thanks!
You won't be able to run a tire near that large with the air suspension. I'm not sure exactly how large you can go with it as I haven't dealt with it and personally am not a fan of it so I don't pay attention. But from what I have read I believe a 285/60/20 or something close to that is the largest you can go with air suspension. I'd recommend doing a search on the forum (use google as it's easier - "largest tire with air suspension site:ramforumz.com") and you should be able to find quite a few threads of guys talking about that.
Old 03-26-2014, 05:27 PM
Geniusgene's Avatar
Geniusgene Geniusgene is offline
Vehicle: 2010 Ram 1500 QC
Color: Inferno red pearl
Geniusgene is on a distinguished road
anyone know the offset of the stock rt 22'' wheels. my buddy just put a set on his 14 slt with stock ride hight. hes running 305-45 and they dont rub. a little math says they are 3/16 of an inch smaller diameter than stock 275-60-20. i want to run that size set up but with aftermarket 22x10's, so i need the offset. any ideas from you rt guys? also, 3/16 shorter should have a minimal effect on speedo error, im thinking around 1 or 2 mph at 70, am i right on this?
BT catch can, Borla pro xs, Afe drop in filter.
Old 03-26-2014, 09:09 PM
Brandon Snyder's Avatar
Brandon Snyder Brandon Snyder is offline
Vehicle: 2007 Dodge ram 1500 Hemi
Color: flame red
Rep:13
Brandon Snyder is on a distinguished road
does it matter the hub bore size when buying after market rims?
True dual flowmasters, 2 12 in Memphis, kicker door speakers, Kenwood head unit , 2.5 ready lift level, 33in mts, fuel hostages 17, Afe cai, bbk 85mm throttle body, weathertech floor mats, Aries bull bar , 2 kc off-road lights, superchips 3865.
Old 03-26-2014, 09:22 PM
Moderator
Rep:2140
Yes it needs to at least be bigger than what your hub is. Off the top of my head I don't remember the spec for a 1500 but I'll try and look it up and get back to you. Most aftermarket wheels are a standard bore and you'll want to get the hub rings to make the wheels hubcentric.
Old 03-26-2014, 09:33 PM
SShadow1974's Avatar
Vehicle: 2016 Ram 1500 Sport w/RAMBox
Rep:166
The 2014 is 78.1mm... Don't know if it changes from year to year though.
S S H A D O W
Old 03-27-2014, 01:20 PM
Moderator
Rep:2140
Ram 1500's hub size is 77.8mm. But as I said most aftermarket wheels are going to have a standard size larger than that. Just specify your truck when you order and make sure you get the hub rings and you'll be good to go.
Old 03-27-2014, 04:26 PM
PFD66 PFD66 is offline
Vehicle: 2016 Ram 3500 DRW
Color: Luxury Pearl Brown
PFD66 is on a distinguished road
I have a 2014 3500 mega, was wondering if 285/75/18's will fit on the stock wheels without rubbing, no lift.
Thanks in advance
Old 03-27-2014, 07:50 PM
Geniusgene's Avatar
thanks bud, i look into those tires. i dont hate the stockers but they do suck in the snow.
