Do you have questions about wheels, tires, etc post them up we will answer :) - Page 25 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-02-2014, 12:02 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Originally Posted by russschultz View Post
I have a stock 09 Dodge Ram Big Horn with the 5.7ltr Hemi and I'm wondering if a thinner tire would see a boost in gas mileage? Currently I have 275/60/20.
Thanks,
Russ
A thinner tire isn't going to do much for you... but a shorter tire would. But we're talking 0.5 mpg max.
Originally Posted by tonw07 View Post
So I should be able to fit a LT275/65R20 tire with the 2" leveling up front? If I calculated it out right this tire is only an inch taller than the stock one and with a 2 inch lift and same width tire I don't believe I should run into any issues?
Yup that will fit no problem.
Old 04-05-2014, 10:43 PM
obxram obxram is offline
Vehicle: 2010 ram 1500 trx4
Trim Level: trx4
Color: gray two tone
obxram is on a distinguished road
Ok finial decision on wheels are method standard 18x9 -12 offset tires are toyo at2
Question is what size 295/70 or 35x12.5 size wise they are very close height and 1 inch different wider. Weight is a huge difference and I have no idea why.
Bilstiens are at 2.1
Thanks in advance
Old 04-06-2014, 10:21 PM
Moderator
Rep:2140
Thanks in advance
With Bilsteins at 2.1" I would recommend the 295/70/18's.
Old 04-15-2014, 04:53 PM
adicted adicted is offline
Vehicle: 2013 Ram SLT Quad Cab Silver
Color: silver
adicted is on a distinguished road
will a 285/75/17 fit on stock 17 inch rims with the front bilsteins at 2.1..Tires are the toyo open country extreme...
truck is a 2013 ram 1500 4x4
Old 04-15-2014, 05:00 PM
Moderator
Rep:2140
Yes sir.
Old 04-15-2014, 06:12 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Yup. Its only 1 size wider over stock.
sales@revelperformance.com
Old 04-15-2014, 07:42 PM
DarkKn1ght DarkKn1ght is offline
Vehicle: 2014 Dodge Charger R/T AWD
Trim Level: R/T Plus
Color: TorRed
DarkKn1ght is on a distinguished road
I'm looking to buy a Ram 1500 Outdoorsman and I'm looking for a wider 17" wheel so I can fit wider and taller tires on it. I like the Ion Alloy 174 but I don't know if they will fit. Ion Alloy sells the wheel in a 17x9 5x5.5 0 offset pattern. Does anyone have any insight? I'm planning on running 315/70/17 Cooper Discoverer AT3's and Bilsteins on the truck.
[CENTER][B][COLOR=Red]2014 Dodge Charger R/T AWD Sport[/COLOR][COLOR=Red] - "Scarlett"[/COLOR][/B]
[URL="https://www.facebook.com/groups/716407895139003/"][B]New Jersey Modern Muscle[/B][/URL]
[/CENTER]
Old 04-15-2014, 08:04 PM
SShadow1974's Avatar
Vehicle: 2016 Ram 1500 Sport w/RAMBox
Rep:166
0 offset will move the centre of the rim out further by 25mm... On top of that, the stock Outdoorsman rim 17" rim is 7" wide... Therefore you will end up with an inch on either side of the centre as well. So, all in all (and Brandon can correct me if I am wrong) you will move the outside of your rim out by 50mm (1 inch = 25mm + the 25mm from the 0 offset).
Going from stock 265 t0 315s is a difference of 50mm or 2 inches. You are already gaining 25mm by the offset of the rim... So you are going to have the tire 25mm further back into the wheel well. When the guys put my wheels on, they told me at full turn I still had more than an inch of space between the tire and anything it would rub on.
I don't know if any of this helped... But I think you'd be OK, especially if you do a level (I have not... I'm stock.)
S S H A D O W
Old 04-15-2014, 09:28 PM
Revel Performance
Rep:1804
I believe this is somewhat explained on the first page and first few posts.
But yes, it will work.
As mentioned above the more negative the offset, the further it is pushed out from the truck.
Stock is +19.05
So 0 is 19mm further out from stock.
Too much negative and you will need more height or trimming. But 0 is a perfect offset for wider tires and minimal to zero rub
Old 04-16-2014, 04:30 AM
Color: TorRed
Stock is +19.05
I read the thread you made about it but I wanted to be 100% sure before I ordered anything. Thanks for your help.
[/CENTER]
