Old 04-16-2014, 07:57 AM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
Stock 17" Outdoorsman wheels are +25 offset. At least mine are.
S S H A D O W
Old 04-20-2014, 08:24 AM
coldwater's Avatar
coldwater coldwater is offline
Vehicle: 2003 Ram 2500 diesel
Color: gray
coldwater is on a distinguished road
I'll shoot. I have load range E tires on my 2500, but seldom use it to tow or haul any real weight any more. The ride is a little harsh over bumpy roads with the full recommended tire pressure. Can I run them at a lower pressure without any ill effects? If so, is there a recommended pressure? Thanks.
Old 04-20-2014, 01:09 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
What psi are you running them at now? You definitely don't need to run them up at or near max when you aren't towing. I'd recommend somewhere around 50-55 psi on the front and 45-50 psi on the rear.
Old 04-21-2014, 06:08 PM
coldwater's Avatar
Color: gray
Truck is at the body shop right now, but I think tire pressure on the door jamb was 75 and 85. I guess I'l drop it down when it comes back and see if it wont improve the ride a bit. Thanks!
Old 04-22-2014, 06:34 PM
tollus tollus is offline
Vehicle: 2014 1500 Ram
tollus is on a distinguished road
If I leave my truck stance stock (2014 1500), but go with a rim like the Fuel Dune with an offset of 1, what is the largest tire I could fit?
I'd like to do something like a 305/55/20. Or even a 295/60/20. I know that will fit with a stock 8" rim, wondering if the offset on the Dune will allow it to fit with a 9" rim.
If I went with a level kit - how big of a tire would fit?
Thanks
Old 04-22-2014, 07:31 PM
terry littlejohn terry littlejohn is offline
Vehicle: 2011 ram 1500 4x4
terry littlejohn is on a distinguished road
for those of us that like the stock chrome clad look, are there any after market replacement chrome covers that can replace damaged stock covers.
Old 04-22-2014, 07:37 PM
Thanks
You'd be able to fit those tires.
Should you level you can do the following
2" = 34" equivalent
2.5" = 35"
Old 04-23-2014, 02:11 PM
ncredibleram's Avatar
ncredibleram ncredibleram is offline
Vehicle: 2014 Ram 4x4
Trim Level: Laramie Crew Cab
Color: Maximum Steel and Silver
ncredibleram is on a distinguished road
Need advice quick. I have a two tone Maximum steel and silver Laramie with OEM flares. I;m set on a 6" zone lift with 35" tires. My question is rim style and offset. I would prefer 0 offset. not sure how aggressive the -12 offset looks. I wish someone could find a picture of my truck online and photoshop Fuel Throttle machined 20x9 with 35s and Fuel Nutz 20x9 with 35s and 18s on 35s. I was dead set on the Xtreme nx-2 in chrome but can only get those in -12 18x9. I'm racking my brain on this since my truck color maximum steel with silver.
Zone 6" Lift, Toyo MT 35x12.5x20, Procomp 6033 20X9 0-offset, Inyati Spray-in Bedliner. 33% tint.
Old 04-23-2014, 04:59 PM
Its a matter of 1/2" difference.
0 offset will stick out approx 1.5" and -12 will stick out 2"
Will you notice it on a truck that's lifted 6"? Probably not....
There will be more comparison going from a 9" wide rim to a 10"
Questions you have to ask yourself is
1) do I want flares
2) how wide of a stance do I want
But again, you're talking 1/2" difference
Old 04-23-2014, 10:17 PM
2" = 34" equivalent
2.5" = 35"
Thanks, I'm back and forth on whether I want to level. I thought the 295/60/20 were practically 34"
Does a 35" tire require that the rear be lifted too? I got a quote from a local shop on a set up with 325/60/20 and they said that the front and rear needed to be leveled and lifted to fit it. The kit they quoted had a level up front and a small spacer in the back....don't recall the amount, but it was small. I thought Bilsteins at 2.8 would do it.
They also said I had to go with a 20x10 rim with a -12 offset to fit that tire. I was hoping to do the 20x9 with a 1 offset so that it doesn't stick out quite as far....would the 20x9 rub?
