Old 04-24-2014, 03:19 AM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Originally Posted by tollus View Post
Thanks, I'm back and forth on whether I want to level. I thought the 295/60/20 were practically 34"
Does a 35" tire require that the rear be lifted too? I got a quote from a local shop on a set up with 325/60/20 and they said that the front and rear needed to be leveled and lifted to fit it. The kit they quoted had a level up front and a small spacer in the back....don't recall the amount, but it was small. I thought Bilsteins at 2.8 would do it.
They also said I had to go with a 20x10 rim with a -12 offset to fit that tire. I was hoping to do the 20x9 with a 1 offset so that it doesn't stick out quite as far....would the 20x9 rub?
I wouldn't go with a 325/60/20 on a leveled truck. You'll definitely have rubbing problems. Especially on a 20x10 -12 offset wheel. A 20x9 0 offset will give you the smallest chance of rubbing. To run a 295/60/20 (about 34.4" tall) you'll need at least a 2" level. To fit a 35x12.5 you'll want a 2.5" level. You can find tons of info in the Guide to Leveling & Wheel and Tire Sizing linked in my signature.
You don't need to lift the back at all to fit a 35" tall tire.
Old 04-25-2014, 01:53 AM
Your rear does not have to be lifted to fit those tires. The front will certainly as it will run when turning without the height.
As for 20x10 -12, you will rub and will have to modify slightly to fit without rubbing.
20x9, 0/1 offset will work better or even a -12 on a 9" wide.
But the 0/1 offset will be fine and rub the least and more than likely will not rub at all.
This is why forum vendors exist.... So we can steer you down the right path
Let us know if we can do anything for you
Old 04-29-2014, 05:46 AM
scasselin scasselin is offline
Vehicle: 2011 Dodge Ram 1500
Color: Hunter Green Pearl
scasselin is on a distinguished road
I have 2011 Dodge Ram CC Sport 4x4 with the 20" Chrome Clad wheels, I have BFG 285/55/20 tires on them and am looking at getting some new rims. The rims I want are 20"x9", 5 spoke, 5 lug, 139.7mm Bolt Pattern, 19.05mm offset, alloy refinished.
First of all will these rims fit my truck and will my tires fit on these rims.
Old 04-29-2014, 01:05 PM
Rep:2026
Yes those are essentially the exact same specs as your stock wheels so they'll fit no problem.
Old 04-29-2014, 09:58 PM
inkdwheels's Avatar
inkdwheels inkdwheels is offline
Vehicle: 2012 RAM 1500
Trim Level: express
Color: flame red
inkdwheels is on a distinguished road
Hello, ordered xd brigades in 20x9 +18 offset and toyo at2's and town fair says they will clear, is this true I've been reading on some of these threads that I need a negative offset, also a rancho 4" lift gets installed first
Old 04-29-2014, 10:14 PM
Rep:2026
What size Toyo's? Can't tell you much without knowing that.
Old 04-29-2014, 10:16 PM
inkdwheels's Avatar
Trim Level: express
Color: flame red
Whoops, forgot to mention that part, 35 12.50 20
Old 04-29-2014, 10:19 PM
Rep:2026
Nope, you won't clear those with a +18 offset wheel. You'll need 1/4" spacers to make that setup work if you already ordered them.
Old 04-29-2014, 10:23 PM
inkdwheels's Avatar
Trim Level: express
Color: flame red
Ok thanks, the tires are on a back order for a few more weeks I'm just gonna tell them I don't want those wheels anymore, thanks for the help, what offset would you say I should get?
Old 04-29-2014, 10:31 PM
Rep:2026
If you want to run a 35x12.5 a 20x9 0 offset is typically the minimum you want to go with. You could go with a -12 offset if you want them to stick out a little further. If you want a deeper lip wheel step up to a 20x10 -12 or -24 offset wheel.
