Old 05-05-2014, 04:39 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Originally Posted by nickali2566 View Post
Ok, I have a 2012 Ram 1500 4x4. I just installed the Rancho Quick Lift shocks up front to level it out. I am getting ready to purchase the tires, but don't know what to get. Rancho recommends 275/65R20, but I want a little bigger. What is the largest tire I can run with the quicklift shocks? I have read 295/65R20. Is this true? Can I go bigger than that? Spacer needed?
Thanks,
Again, the Guide to Leveling & Wheel and Tire Sizing linked in my signature will tell you everything you need to know.
Old 05-05-2014, 09:32 PM
cSMITH3100's Avatar
cSMITH3100 cSMITH3100 is offline
Vehicle: 2013 Dodge Ram shorty
Rep:73
cSMITH3100 will become famous soon enough
I am looking at ordering at set of Fuel 20x10 -44 deep lip Octane's.
I have a 4" lift and Bilsteins set to .7 with 35" Nitto Trail Grapplers on stock 20" sport rims and 1/4" spacers now, but there is slight rubbing on sway bar on pass. side.
I dont plan on running fender flares.
what is everyones thoughts or suggestions on -44 offset? too much? too hard on vehicle for wear and tear?
with a -44 offset and the 4" lift will there be any rubbing issues with the inner fender? will i need to trim or should it clear no problem?
I deff love the look of the wide stance, and will be going with a far amount of offset, just wondering if i should go with just a hair less then -44?
Old 05-06-2014, 12:43 AM
Rep:2026
I'd stick with a -24 offset. That will already give you a really wide stance with the 4" lift. They should be sticking out about 3" with your 35's. If you don't plan on running flares that's already far past legal.
Old 05-06-2014, 02:05 AM
cSMITH3100's Avatar
Rep:73
Thanks for he reply brandon! yeah I think I have decided on the 20x10 -24 Octanes.. CdnoilRAM gave me some good info and aided in my decision!
cant wait to get them on the truck!t
Old 05-11-2014, 09:36 PM
kott kott is offline
Vehicle: 2008 Dodge Ram
kott is on a distinguished road
Looking for help with offset. I'm looking at raceline raptor wheels 20x9 would like them to stick out about 1.5 to 2". I'm putting Bf Goodrich at 285/65r20. I have a 08 1500 with bilstien 5100 set at 2.8". can not find anything but +20 offset for these. So I just would like to get some help before I pull the trigger. thanks
Old 05-12-2014, 12:55 AM
Rep:2026
With those tires on a 20x9 -12 offset you'll be sticking out about 1.25-1.5" past the fender. If you want them out more I'd recommend going to a wider tire.
Old 05-15-2014, 11:10 AM
TheMeanFahim85's Avatar
TheMeanFahim85 TheMeanFahim85 is offline
Vehicle: 2013 RAM Laramie
Trim Level: 1500 Laramie
Color: Black w/ Silver
Rep:13
TheMeanFahim85 is on a distinguished road
Will 35/12.50R20s clear on a 2013 Ram 1500 with the Rough Country 2.5" Leveling Kit? I've been finding mixed responses all over the place and figured I'd check here. Also I'd like them to stick out a little but am not sure if they would rub...forgive the noob-ness lol
Old 05-15-2014, 05:52 PM
Rep:2026
With the correct wheel offset, yes. Check out the Guide to Leveling & Wheel and Tire Sizing linked in my signature. It should help you out.
Old 05-15-2014, 07:29 PM
hoamskilet hoamskilet is offline
Vehicle: 2007 Dodge Ram Quad Cab
Rep:79
hoamskilet will become famous soon enough
trying to figure out tire sizes is kicking my butt. The wheels that I'm contemplating getting are the Fuel D251's (20 x 10) which according the specs have a -19 offset (4.75" backspacing). I'm stock at the moment and have been trying to decide if I should stay stock or do Bilstein 5100's, and which tire size would work for each option. I noticed in your guide you said to stick with a 295/60/20 with the shocks. Do you think that size would be good with a rim that has the specs I laid out? What size tire would work if I stayed stock? Thanks for any advice.
Old 05-15-2014, 07:43 PM
Rep:2026
If you stay at stock height the maximum tire size you'll be running is a 33". But that may even be pushing it with that rim width and offset. I would run Bilsteins at 2.8" and either 295/60/20's or 35x12.5's depending on how much tire you want.
