Old 05-29-2014, 01:30 PM
redrik redrik is offline
Vehicle: 2013 Ram 1500 QC Black Express
Rep:43
redrik is on a distinguished road
Ya they'll fit no problem since they're only 32" tall.
Awesome thanks. I figured I was good with the height it was the width that I wasn't sure about.
Old 05-30-2014, 10:25 PM
CCBubba CCBubba is offline
Vehicle: 2014 Ram 2500 4X4
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
CCBubba is on a distinguished road
Default Question on wheel size
I'm going to get my 2014 2500 4X4 lifted 4 inches. The shop doing the lift said the largest tires they can fit are 35's and that the minimum size wheel needs to be 20 inches. I would prefer 17 or 18 inch wheels. They said it has to be 20 because the brakes are too big? Is this true? Thanks.
Old 05-31-2014, 12:16 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
17's are the minimum because of the brakes. Most HD Rams come with 17's stock. It's only the 2014's that have started coming out with 20's stock. So your shop is wrong. Regarding the tire size you could fit larger than 35's if you wanted to... but it partially depends on the wheel offset you plan on running as well. Most guys run a more negative offset for a wider stance which means you're more limited in height.
Old 05-31-2014, 02:35 AM
TheRudeDog TheRudeDog is offline
Vehicle: 2013 Ram
TheRudeDog is on a distinguished road
Has anyone tried 305/45/22s on a 2013 Laramie with the air suspension? And did they rub turning the wheel all the way? Thanks!
Old 05-31-2014, 08:41 AM
Thanks for the response Brandon. I was hoping I could go smaller.
Old 05-31-2014, 10:07 PM
I really need some direction from the forum. I'm getting two very different lift recommendations from the two different shops in my area. I prefer a 4inch lift on my 2014 2500 diesel. One says they can do a 4 inch but it has to be BDS. The other doesn't have a 4inch option and is pushing me towards a 6inch pro comp lift. What's the ideal setup for my truck? Thanks
Old 06-01-2014, 12:51 AM
Rep:2032
The ideal setup is the one you want. I know the BDS kit is compatible with the new 2500 coil suspension. I haven't heard anything about ProComp coming out with a kit for it. BDS makes great kits and I'd be running their kit far before a ProComp kit. Plus if you go to a 6" kit you'll want to run 37's to fill up the wheel well. If you want to stick with 35's a 4" lift is definitely the way to go.
Old 06-01-2014, 08:18 AM
Will I experience a significant loss in gas mileage with 37's?
Old 06-01-2014, 09:07 PM
jduke91 jduke91 is offline
Vehicle: 2010 Dodge Ram 1500 4x4 QC
jduke91 is on a distinguished road
I have a 2010 Dodge Ram 1500 4x4 Quad Cab with a leveling kit. I am putting new tires and wheels on my truck. Can you advise whether I will have rubbing issues with 305x55r20 Procomp Extreme All Terrain tires on 20x9 wheels with a 0 offset and 5 backspacing? Also about how far will they stick out so I know what kind of fender flares I need.
Old 06-01-2014, 11:37 PM
rumpity rumpity is offline
Vehicle: 2011 Ram Sport
rumpity is on a distinguished road
I am new to the forum, so my question may have already been answered elsewhere. I have a 2011 Ram Sport standard cab, short bed with 3:92 gears and stock tires. I want to go to a 33" or 35" tire without a lift. Is this possible just by reducing the wheel diameter in order to keep the overall tire diameter the same as stock?
Thanks, Rumpity
