MOPAR DECALS
Old 06-01-2014, 11:56 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Originally Posted by CCBubba View Post
Will I experience a significant loss in gas mileage with 37's?
I lost about 1.5 mpg going to 37's from stock tires on my Cummins. My truck is fully tuned and deleted though.
Originally Posted by jduke91 View Post
I have a 2010 Dodge Ram 1500 4x4 Quad Cab with a leveling kit. I am putting new tires and wheels on my truck. Can you advise whether I will have rubbing issues with 305x55r20 Procomp Extreme All Terrain tires on 20x9 wheels with a 0 offset and 5 backspacing? Also about how far will they stick out so I know what kind of fender flares I need.
Those will fit no problem. Should be sticking out past your fender by about 1".
Originally Posted by rumpity View Post
I am new to the forum, so my question may have already been answered elsewhere. I have a 2011 Ram Sport standard cab, short bed with 3:92 gears and stock tires. I want to go to a 33" or 35" tire without a lift. Is this possible just by reducing the wheel diameter in order to keep the overall tire diameter the same as stock?
Thanks, Rumpity
Stock tires are 33" tall so that's not an issue. You won't fit 35's without a level though. Reducing the wheel diameter does absolutely nothing to the overall tire diameter...
Old 06-02-2014, 10:30 AM
Power Wagon's Avatar
Power Wagon Power Wagon is offline
Vehicle: 2013 Ram
Trim Level: Quad Cab 4x4
Color: Deep Cherry Red Crystal
Rep:45
Power Wagon is on a distinguished road
Default TPMS on 2014 2500 HD w/ 6.4 hemi
Wondering if any info is around with regard to TPMS problems on a new 2500HD RAM ? My brother-in-law has one and he has been having recurring trouble with the TPMS. It's at the dealer now for the 2nd time. The display keeps showing his 2 fronts in trouble. His recommended pressures are 60 psi front and 80 psi rear. Doesn't matter how high he pumps up the fronts, the display keeps saying there is a problem in the fronts. The first trip back to the dealer resulted in a reflash of the computer which worked for about 50 miles and the problem returned. The dealer said they think they must get new sensors. Anybody else having this issue ?
Old 06-02-2014, 10:13 PM
kewlguy53403 kewlguy53403 is offline
Vehicle: 2011 Dodge Ram Sport
Rep:25
kewlguy53403 is on a distinguished road
I'm considering going from a 33" to a 34" or so tire with a 22 inch rim. What are the commons sizes available to get close to this that people have done? Any pics?
Raptor Step & Bed Rails | K&N | BakFlip HD | Halo Proj. LIghts | Recon Brake Lights | DDM HIDs | Big Rig Lights | Night Raider Taillight Bar | Volant CAI | Magnaflow 18 | MGP Caliper Covers | Lower Billet Grill | 20% Tint | Blistein 5100 @ 2.8 | 34" Tires | Dipped Chrome
Old 06-03-2014, 12:31 AM
Moderator
Rep:2140
What kind of stance are you looking for? Flush, tucked under, wide?
Old 06-12-2014, 12:12 AM
draken's Avatar
draken draken is offline
Vehicle: 2010 Dodge Ram 1500 CC Bighorn
Trim Level: Bighorn. SLT
Rep:34
draken is on a distinguished road
i was curious if there is a tires out there that says 35" but is a little bigger? i know there are ones that are smaller then 35's even though they claim to be 35's.
2010 Ram 3500 Laramie 5" Lift | 35" Nitto Trails 20" Havook Wheels | Sinister EGR Delete | 5" MBRP Turbo Back Exhaust | 6" Black Flo Pro Tip | EFI Live Anarchy Custom Tune | CSP5 Switch | Custom Retrofit Headlights 3k HID Fog Lights
Old 06-12-2014, 01:21 AM
Moderator
Rep:2140
325/60/20's are an oversized 35.
Old 06-12-2014, 01:52 PM
draken's Avatar
Rep:34
awesome thank you. Do i have to get size 20 rims?
Old 06-12-2014, 02:07 PM
Moderator
Rep:2140
Nope, not at all. 17" is the smallest you can go to clear the brake calipers. But you can go with any size you want 17 or above.
Old 06-12-2014, 02:08 PM
draken's Avatar
Rep:34
im not to educated with tire sizes haha, i put that in a tire size converter and replaced the 20 rim size with 18 and it made the tires smaller?
Old 06-12-2014, 02:30 PM
Moderator
Rep:2140
Yes. With metric sized tires the rim diameter affects the overall diameter. In a 325/60/20 tire for example. The first number is the tread width in millimeters, the second is the aspect ratio which is the percentage of the tread width that the sidewall of the tire is. The third number is the tire diameter in inches. To do a quick calculation of the overall tire width and height you use these formulas:
Width: 325/25.4 = 12.80
Height: (((325x0.6)x2)/25.4)+20 = 35.35
So now if you changed that to an 18" rim you're only adding 18" to the overall height of the tire while the sidewall stays the same height. So to compensate for that and get a larger tire you need to increase the aspect ratio to increase the overall size of the tire. You could look at a 325/65/18 (34.63"x12.80") or a 325/70/18 (35.91"x12.80"). But just because we can come up with those numbers in a metric size to come up with the overall tire size you are looking for doesn't mean a manufacturer actually makes them. Your best bet is to go to the manufacturers website and pull up their full list of tires and go to the page that lists all the specs including the overall height and width when mounted. That way you know exactly what you're getting.
