Old 06-12-2014, 04:32 PM
draken's Avatar
draken draken is offline
Vehicle: 2010 Dodge Ram 1500 CC Bighorn
Trim Level: Bighorn. SLT
Rep:34
draken is on a distinguished road
Thank you very much that helped out a lot. I appreciate your help!
Zone 6" with 5" rear, Bilstein 5100s, Toyo M/T 315/70/18, 18x10 MotoMetal 967s, Bushwacker Pocket Flares, S&B CAI, Flowmaster 10 series, Diablo Trinity With Hemifever Tune, Drop in K&N Filter, Retrofitted headlights, 5k morimoto HID, 6k Fogs, Metal Tonneau Cover, Plastidipped Bumpers and Grille
Old 06-16-2014, 11:52 PM
redram21 redram21 is offline
Vehicle: 2010 ram 1500
redram21 is on a distinguished road
I have a 2010 ram 1500 sport and I'm in the market for new tires. I dropped down to 18's (fuel octanes, +1 offset, 18x9). I've decided on trail grapplers but I'm Unsure which size to go. No level since the bilstiens are back ordered still. Would 285/65/18 fit without any rubbing?
Anyone have pictures of the 285s ?
Old 06-17-2014, 06:37 AM
Fredl Fredl is offline
Vehicle: 1979 Chevrolet Camaro
Fredl is on a distinguished road
perhabs this section is better for my question:
regarding 33x12.50 nitto mud grapplers and 20x9 with 0 offset wheels:
Will i need a leveling for 33tires?
Will the tires stick out of bushwalker fender flares?
truck is 2006 1500 quadcab
Old 06-17-2014, 04:18 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
That tire is shorter than stock, it will fit no problem.
You should be fine with that setup. The width of your stance without a level as the potential to give you a slight rubbing problem on the back of the inner fender but with only a 0 offset and a 33" tall tire you shouldn't have a problem.
No, they'd be tucked under pocket flares.
Old 06-18-2014, 04:04 AM
hi brandon,
thanks for feedback.
do you think a 2WD with 2.5" level will be fine with this setup without rubbing?
Old 06-18-2014, 12:24 PM
Rep:2032
hi brandon,
Yes, with a 2.5" level you definitely won't have any issues.
Old 06-23-2014, 10:12 PM
rodgerdodger rodgerdodger is offline
Vehicle: 2002 Ram 1500
rodgerdodger is on a distinguished road
Hey I'm looking at buying a 5" lift for my 2002 1500 4x4, and I've narrowed it down to either Zone or Rough Country. They are both about the same price but I've heard some people say Zone is higher quality and it is made by BDS. Is this true? What exactly about the zone kit is higher quality? I'm just skeptical because I know many people run the RCX lift with no problems
Old 06-24-2014, 03:43 PM
Rep:2032
Yes Zone is owned by the same company that owns BDS so they are essentially sister brands. Zone is just the more affordable option. For an 02 the Zone and RCX lifts are going to be very similar. Zone may be slightly better, but not by much. They do provide more options on most of their lift kits though.
Old 06-24-2014, 08:41 PM
Ok thanks, i appreciate the help. Now i was thinking about getting some 17x9 Raceline Assault rims with a 0 offset. I wanted -12 offset, but apparently they dont make those wheels with -12 offset. But what do you think about that offset? Im running 315/70/17s.
I have fender flares on my truck and id like the tires to be flush, but im pretty much set on those wheels. The only other ones I like that have a -12 or -24 offset are almost twice the price.
Also i noticed the Zone lift says I need 4.5" backspacing, whereas the RCX lift says 5.5. Any idea why that is?
Old 06-25-2014, 01:45 AM
Rep:2032
What flares do you have on your truck? And how much do they cover past the fender?
That's probably just be because of the knuckle design.
