Old 06-25-2014, 07:10 PM
rodgerdodger rodgerdodger is offline
Vehicle: 2002 Ram 1500
rodgerdodger is on a distinguished road
The flares stick out about an inch from the fender. Im not sure what brand they are
Old 06-25-2014, 07:44 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Originally Posted by rodgerdodger View Post
Ok thanks, i appreciate the help. Now i was thinking about getting some 17x9 Raceline Assault rims with a 0 offset. I wanted -12 offset, but apparently they dont make those wheels with -12 offset. But what do you think about that offset? Im running 315/70/17s.
I have fender flares on my truck and id like the tires to be flush, but im pretty much set on those wheels. The only other ones I like that have a -12 or -24 offset are almost twice the price.
Also i noticed the Zone lift says I need 4.5" backspacing, whereas the RCX lift says 5.5. Any idea why that is?
What flares do you have on your truck? And how much do they cover past the fender?
That's probably just be because of the knuckle design.
17x9 0 offset with 315/70/17 will stick out past those flares by about 1" (to the outside of the tire). -12 offset would stick out 0.5" further.
Old 06-25-2014, 11:04 PM
ram-express4x4 ram-express4x4 is offline
Vehicle: 2014 Ram 1500 4x4
ram-express4x4 is on a distinguished road
Exclamation backspacing/offset
Hi i have a 2014 ram 1500 express, single cab short box 4x4 I want to put the bilstein 5100 at 2.1 height, I would like to run 295/75R17 (or bigger if I can), on a 17x9 rim (not a stock rim). I would like the tire to stick out a little bit but not far enough I need fender flares what backspacing and offset would I need I was looking at 4.53" backspace and -12 offset would that be too much or not enough.........
Old 06-26-2014, 12:01 AM
Rep:2026
A 295/75/17 is already pushing it for only having Bilsteins at 2.1". You could go wider but wouldn't want to go any taller.
If you want them to stick out about 1" past the fender you'll want a 0 offset rim.
Old 06-26-2014, 05:22 PM
Ok what size tire would you run with them at 2.1, and on 17x9 and what back spacing and offset would be best. Would the -12 offset and 4.53 not work? (would it be to far out or in). My stock 20's are +19 and 5.75" and they sit pretty much flush with the fender.
Old 06-26-2014, 05:42 PM
Rep:2026
Well depending on what tire you want, a 295/75/17 may not exist. I haven't seen that size from Toyo or Nitto. I'd probably go to a 305/70/17 with a 17x9 0 offset wheel. A -12 offset will probably be sticking out further than you want.
Old 06-26-2014, 05:56 PM
Ok thanks a lot for the quick reply's, I'm not looking to go with a real aggressive tire thinking maybe the good year duratracs or something ALterrain.
Old 06-28-2014, 06:59 PM
KingKB82's Avatar
KingKB82 KingKB82 is offline
Vehicle: 2013 Ram 4x4 1500
KingKB82 is on a distinguished road
Hello All,
Have a 2013 ram express.. Just bought helo he835 wheels now I am going to be looking for some aggressive tires.. I wanna move up a few size but of course I am worried about fitment and speedometer issues.. what is a solid size to move up to? Also I am thinking about putting a leveling kit on it and maybe some spacers as well..
Thanks!
Old 06-28-2014, 08:58 PM
Rep:2026
Originally Posted by KingKB82 View Post
Hello All,
Thanks!
Check out the Guide to Leveling & Wheel and Tire Sizing linked in my signature.
Old 06-28-2014, 09:43 PM
KingKB82's Avatar
Thank you!
