Old 06-30-2014, 08:02 PM
ram-express4x4 ram-express4x4 is offline
Vehicle: 2014 Ram 1500 4x4
ram-express4x4 is on a distinguished road
Well depending on what tire you want, a 295/75/17 may not exist. I haven't seen that size from Toyo or Nitto. I'd probably go to a 305/70/17 with a 17x9 0 offset wheel. A -12 offset will probably be sticking out further than you want.
Hi sorry to ask another question but I cant seem to find a 17x9 rim I like with 0 offset. what about -6 how far out from the fender will that sit?
Old 07-01-2014, 01:43 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
6mm is 1/4" so it will be sticking out a 1/4" more than a 0 offset. A 305 wide tire on a 17x9 -6 offset should stick out around 1.25".
Old 07-02-2014, 03:25 PM
DirtDog DirtDog is offline
Vehicle: 2014 dodge Ram reg cab
Color: Blue
DirtDog is on a distinguished road
Greetings,
I have just put a Daystar 1 & a half leveling kit on my new 2014 reg cab 2 wheel drive. What is the biggest tire I can run on the stock 20 in wheels?
Tex's.
Old 07-02-2014, 04:41 PM
Rep:2036
Originally Posted by DirtDog View Post
Greetings,
Tex's.
With only a 1.5" level on a 2wd you won't be able to go much larger than stock. A 285/60/20 is about the biggest you're going to be able to fit.
Old 07-03-2014, 06:55 PM
birm birm is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Sport Crew Cab 4x4
birm is on a distinguished road
Largest tire I can fit on the stock Sport 20" wheel (13 Ram Sport), I have the Bilistein 2.1" level upfront if that helps.
I prefer an offroad or AT tire, I love the look of the Toyo Open Country MT
Old 07-03-2014, 07:01 PM
Rep:2036
Read through the Guide to Leveling & Wheel and Tire Sizing linked in my signature. It explains a few of the different sizes you can run.
Old 07-03-2014, 07:03 PM
The stock Sport wheel is 20x8 or 20x9?
And thank you, I will!
Old 07-03-2014, 07:14 PM
Rep:2036
20x9
