Old 07-29-2014, 06:36 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
Originally Posted by 69Ram View Post
OK, I have read most of this thread but have not seen this exact question. If i have missed it I apologize.
The truck is a 14 Longhorn, leveled with Bilsteins.
Here are my will it fit or rub questions.
Set up 1 - 20x9 +12 w. Nitto TGs 295/60 20
Set up 2 - 20x9 +12 w/ Nitto TGs 295/65 20
Set up 3 - 20x10 -12 w/ Nitto TGs 295/65 20
With a 295 wide tire I would recommend sticking with a 9" wide rim to avoid having the tire look stretched. You could run anywhere from a +12 offset to -12 offset depending on how far out you want the tire to stick. With only being leveled you'll probably want to stick with the 295/60/20's. You could probably run the 295/65/20's on a 20x9 +12 offset but you may have rubbing near full lock. Plus they'll look pretty stuffed in the wheel well.
Old 07-29-2014, 07:49 PM
katokahn99's Avatar
katokahn99 katokahn99 is offline
Vehicle: 2013 2500 CTD Laramie Mega 4x4
Color: Black Gold Pearlcoat
Rep:14
katokahn99 is on a distinguished road
This is an amazing thread!!! Thanks for doing this, guys!
OK, here's my question: I'm thinking about going with 285/75R17 on my stock wheels for my 2013 2500 Cummins Mega Cab 4x4. Would I need a level or would they fit? What, if any, issues should I anticipate?
Old 07-29-2014, 07:55 PM
Rep:2067
They should fit no problem with no issues at all. The only thing that will be off is your speedo/odometer
Old 07-29-2014, 09:19 PM
69Ram's Avatar
69Ram 69Ram is offline
Vehicle: 2014 Laramie Longhorn
Trim Level: Longhorn
Rep:13
69Ram is on a distinguished road
Thanks Brandon, you have removed the anxiety for me to order these over the Internet really appreciate what you've done with this thread thank you!
Old 07-29-2014, 09:38 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
All options will work.
Mind you -12 will stick out further Thank option 1 or 2
You may require minor trimming but nothing to worry about.
sales@revelperformance.com
Old 07-30-2014, 12:38 AM
katokahn99's Avatar
Rep:14
Thanks, brother. Yeah, I'll get it re-flashed for the new tire size when I put them on.
Old 07-30-2014, 10:17 AM
69Ram's Avatar
Rep:13
Thanks FastNugly
Old 08-01-2014, 09:24 AM
Diablo Diablo is offline
Color: Mineral Gray
Diablo is on a distinguished road
Originally Posted by Diablo View Post
Guys forgive me because I'm sure this has already been asked. But I'm going cross eyed searching posts.
I have bilsteins up front set on max setting and stock on the rear. Can I run Nitto 35/12.50/17 on 17/8 wheels with 0 offset without any issues?
Again I've been searching for hours and have been lurking on this site for sometime. I guess this is my coming out party!
Thanks
Jeremy
Anybody happen to be running this setup that could post a picture?
Old 08-01-2014, 01:38 PM
zrboy's Avatar
zrboy zrboy is offline
Vehicle: 2011 Dodge Ram
Trim Level: Crew cab sport
Color: Brilliant Black Pearl
Rep:27
zrboy is on a distinguished road
If anyone is curious.. I managed to put 305/55/20 Toyo open country AT 2 extremes (33x12.5x20) on my factory rims with only a 2.5 leveling kit, used 1/4 spacers and have no rubbing issues at all.. after reading all the forums on the topic I decided to pull the trigger on that setup and im so glad I did, looks great!
2011 1500 sport CC / 2.5" front,1" rear Readylift leveling kit / 285/65/20 BFG All Terrain A/T KO II tires / 1/4" wheel spacers / 14" magnaflow muffler by mufflex / Throttle body spacer K&N drop in air filter with 3" bottom Inlet air tube / Tailgate assist / Debadged "Ram 1500" / Stubby antenna / Tinted tails
Old 08-01-2014, 01:46 PM
Rep:2067
http://www.ramforumz.com/showthread.php?t=139401
