Old 12-24-2013, 05:45 PM
lowfast lowfast is offline
Vehicle: 2014 Ram 1500 CC 4x4
Trim Level: 1500 Longhorn 4x4
Color: Western Brown Monotone
Rep:92
lowfast will become famous soon enough
Originally Posted by BlkXpress25 View Post
I have a 2013 Black Express Crew Cab. It came with the painted 20x8 rims. On the Tire and Wheel fitment sticky it states that 295's will fit on the rims without rubbing ( I will quote at end of page). The problem I am having is that no reputable tire companies are wanting to mount on the tires that I want. I am wanting the G Force T/A KDW2 in 295/45/20 instead of going the usual route of lowered trucks of the Nitto 420s (285/50/20). My reasoning for this is that on my 03 Cobra I couldn't get the G forces to slip, but I have heard that even on the rams that the nittos slip a bit.
My question is 2 part:
1) Can anyone confirm that the 295 width will fit on a 20x8 wheel?
2) Does anyone know a reputable, nationwide shop that will mount these?
" Exception for fourth gens with 8" wide stock rims: There is an exception to the above general rule for fourth gen trucks with the stock 8" wide rims. The narrower rim pulls the sidewall in more than the wider rim and allows fitment of a wider tire. Members with the 8" rims have confirmed no rubbing with 295/60/20 and 295/65/20. I personally have not seen confirmation of anything wider fitting but that doesn't necessarily mean it will not."
I had 295/45's on my ford on 20x9's and the tire had quite a bit of bulge, 20x10 would have looked better. IMHO 295 with a 45 or less aspect ratio is too wide for an 8" rim. Not an issue with higher aspect ratio tires like a 60 or 65. It may fit but will have a serious sidewall bulge and will not handle very well. I would either go wider on the rims or narrower on the tire. Again, just my opinion. What rim width does the manufacturer of the tire recommend?
2014 Ram Longhorn CC 4x4 - Born 01/10/14, Western Brown, HEMI, 3.92, LS, AMP PowerSteps, Rancho RS9000 QuickLift and 275/65-20 DynaPro ATMs
2010 Lexus IS-F - Joe-Z Intake
1965 Ford Falcon Hardtop - ProTouring Monster in Progress, 4.6 V8, TCI Suspension, 18x8 & 18x11 Team III Wheels
Old 12-26-2013, 01:21 AM
ksgries ksgries is offline
Vehicle: 2014 Ram 1500 QC
Rep:15
ksgries is on a distinguished road
Im getting blistens front and rear, and a 1.25 rcx body lift. Will 35/12.50/20s fit on the stock 20x9s without any rubbing if I set front blistens to 2.1 or 2.8?
Or should I just get new wheels with a 0 offset?
Instagram: @krisgries
Old 12-26-2013, 04:24 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
What type of tire? You should be able to clear them on stock rims with 1/4" spacers but it's not a 100% guarantee if you're going with Toyo MT's or Nitto Trail Grapplers since they're actually 13.4" wide. But any other 35x12.5 should clear no problem. Getting new rims is obviously an option as well if you want them.
Old 12-26-2013, 12:56 PM
Rep:15
im going with federal courgia m/t(cheapest haha) if I can get away with using the stock rims I will.
Old 12-26-2013, 07:37 PM
Rep:2026
Yup, you'll be able fit those tires on the stock rims with 1/4" spacers. They only measure 12" wide mounted.
Old 12-26-2013, 11:33 PM
RCSB11 RCSB11 is offline
Vehicle: 2011 Ram 1500
RCSB11 is on a distinguished road
I have a 2011 ram with a rancho quick lift, can I run nitto trail grapplers 285/75r17 on my stock 17x8 rims without rubbing?? Without a spacer?
Old 12-27-2013, 12:15 AM
Rep:15
if I go for new wheels do I or should I get a hub centric wheel? Or does it not really matter?
Old 12-27-2013, 06:22 PM
Rep:2026
Yup you should be good with that set up.
Very few aftermarket wheels are actually hub centric but most of them will come with adaptor rings to make them hub centric for your truck. You want to make sure you get those rings.
Old 12-27-2013, 08:16 PM
[QUOTE=brandonjansen;1277920]Yup you should be good with that set up.
Awesome! Great! Gonna pick them up tomorrow!
Old 12-29-2013, 12:45 PM
medic18d medic18d is offline
Vehicle: 2013 express cc 5.7 hemi
Trim Level: blacktop edition
medic18d is on a distinguished road
Originally Posted by Bully's Performance View Post
I see everyday lots of questions about wheels and tires showing up, we would be more than happy to help ya'll out we will monitor this thread daily so if you have questions about wheels/tires, what will fit, what won't etc, etc. Feel free to post them up and we will answer as efficiently and quickly as we can
Thanks
Jeremiah
p.s. What this thread is NOT is a quote thread, please do not ask for pricing in this thread as that is not this threads intention, if you need a quote please ask in our vendor thread as that is the appropriate location for that, or you can email us.
hello sir what is the largest tire size i can use with
2013 ram hemi express 4x4 20" wheels ?
without any scrubbing
thx
