2009 ram 2500 5.7L grinding noise front end while driving :Wow1: - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-24-2013, 04:57 PM
JustinW JustinW is offline
Vehicle: 2009 dodge ram 2500
Trim Level: Texas edition
JustinW is on a distinguished road
Question 2009 ram 2500 5.7L grinding noise front end while driving :Wow1:
Noise does not happen while idle, starts to grind upon movement. The speed or frequency of the grinding noise increases with speed. It appears to be coming from front left end. It is fairly loud and I pretty much know it is coming from the front left tire area because when driving next to concrete dividers the sound is dramatically louder when wall is on left.
The pads do need replacement, but have only been squeaking for a couple weeks. Does not pull left or right while braking or not, and noise does not change while braking.
Old 10-24-2013, 05:07 PM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
Sounds like a unit bearing.
Just Got it, Give me time!
Old 10-24-2013, 05:38 PM
How would I determine if that's the problem?
Old 06-17-2014, 04:15 PM
BIGDOGD's Avatar
BIGDOGD BIGDOGD is offline
Vehicle: 2009 dodge ram 1500
BIGDOGD is on a distinguished road
Default same problem here
same grinding sound that starts as soon as i get up to 15MPH and gets louder as i go faster. Brake pads changed and sound is still there. What should i do now?
Old 06-18-2014, 06:46 AM
BULLRAM's Avatar
BULLRAM BULLRAM is offline
Vehicle: 2009 Dodge Ram 2WD
Trim Level: slt- lonestar
Rep:61
BULLRAM will become famous soon enough
I also believe it is the front hub...your wheel bearings come with the hub , lug nut studs, and sensor all in one, easy to change, jack up the wheel , take off the wheel, then spin it with your hand, listen for a scraping or grinding noise to come from it, if the weight of the wheel is on it sometimes it wont make as much noise, if you are not sure take the other side off also and compare the sounds, you probably will hear it very well, just did mine last weekend... wheel off, take caliper off, take caliper bracket off, take off rotor, remove 3 bolts holding on hub,remove sensor connector from inner fender, , tap from backside , and its off, change them both, if one is bad chances are the other doesnt have long...
Old 07-09-2015, 10:32 AM
SuperHemi SuperHemi is offline
Color: Inferno Red
SuperHemi is on a distinguished road
Yes...Wheel Bearing...having mine changed now as we speak. Do them both.
Old 07-09-2015, 08:37 PM
huntert's Avatar
huntert huntert is offline
Vehicle: 2009 dodge ram 1500 ST
Color: Austin Tan Pearl
Rep:16
huntert is on a distinguished road
might also wanna check cv axles before if your truck is 4x4. had the same initial thought of it being a hub and upon investigation i found that instead i had just made my cv joint explode
Westin black step bars, Diablo intune, 35x12.50x18 Nitto Trail Grapplers, 18x9 -12 offset MAYHEM CHAOS wheels. 2.5 inch dual exhaust with a custom made x-pipe before dual dynomax race bullets, topped off with rectangle tips.
Old 09-07-2015, 10:57 PM
ramowner4 ramowner4 is offline
ramowner4 is on a distinguished road
cool thread
Old 09-09-2015, 03:42 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:801
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
anyone remember when you could just change the wheel bearings? easy job and very few dollars.
Old 09-12-2015, 12:38 PM
rustypipes12 rustypipes12 is offline
Vehicle: 2009 Dodge RamTRX4
Trim Level: TRX4
Color: Blue
rustypipes12 is on a distinguished road
I just changed my left front hub assembly and it was NOT an easy job! I had to remove the Knuckle and use a 5 ton press to get the hub assembly out! I cleaned it up(the knuckle) and installed the new one, took it back to the dealer and had a front end alignment and inspection done. It failed inspection the first time because of the bearing.
My '09 Ram trx4 has 30,000 miles on it. I changed the bearing two weeks ago and today went and got 4 new tires put on at a place where they check the alignment for free. They couldn't check the alignment because the new bearing has too much play! I watched the guy move the tire and did see some movement at the boot so now I'm wondering if I have a bad CV joint?
front end noise, grinding noise, noise front end, u joint noise
