Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Dodge Ram Decals
Old 10-29-2014, 06:29 PM
Ramnugget77 Ramnugget77 is offline
Vehicle: 2005 dodge ram
Ramnugget77 is on a distinguished road
Default No parking lights
I just went and yesterday to get my inspection sticker and I failed for the parking lights not turning on. All other lights work. I checked fuses and relays. I don't know to much about electrical so I hope someone can help me.
Old 10-30-2014, 02:36 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
I believe those are on a fuse. Check both sides of the fuse. Scratch that. Pull the fuse out and replace it with a known good fuse.
Could also be the switch. They are not too expensive. Check your local parts recycler and how much a used switch from an early 3rd gen Ram would be.
Old 10-31-2014, 04:22 PM
I'm looking for a temporary fix. Does anyone know how to jump power from some other place
Old 11-16-2014, 11:06 PM
fj5gtx fj5gtx is offline
Vehicle: 2004 Dodge Ram 1500
fj5gtx is on a distinguished road
The FCM sends a gnd signal to the parking lamp relay, though the ICM circuit board (fuse box). Losing all your parking lights all at once is a tell tale sign of the fuse box circuit board corrosion issue. You can check your relay, but my $ is on a failed circuit board. There is a video on youtube, check out DR IPM REPAIR there. I also saw someone wire wrap from the FCM pin to the relay leg as a temp fix... that is on youtube as well.
Here is a picture of mine, I pulled the box and separated the board. The manufacture did not completely coat the board, you can see where the thick line ends... and then you see that big spot where my trace is all eaten away :-(
Its pretty much an epidemic problem, that dodge of course doesn't admit there is a problem. Replacement is expensive, there are two models.... mine happened to be the more expensive one at $675 locally, about $450 online plus shipping.
Old 11-19-2014, 05:35 PM
Rep:2968
^^^^^^^^^^ Good call and thanks for the post!
