Power Window Control Panel Loose.... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > MOPAR NATION - Dodge Ram Club Regional Chapters! > Dodge Ram Forum CANADA
Old 11-25-2013, 06:53 PM
AlbertaRebel AlbertaRebel is offline
Vehicle: 2004 Dodge Ram
AlbertaRebel is on a distinguished road
Question Power Window Control Panel Loose....
Hello:
I am looking for some advice or help. My control panel for the power window/door lock buttons appears to be loose and when I press down on the buttons they lower as if it's not secured in position. Is there a clip or a screw that is broken or missing from inside the door panel or is there a way for me to look inside there. Thanks for any advice or help offered.
AlbertaRebel.
Old 11-26-2013, 10:56 AM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
There are 2 phillips screws that hold the unit to the trim ring. If you are careful you can pry it up. Good news, the trim ring is very cheap to replace. Buy the trim ring from dealer and you can see exactly how it goes together. BTW, I once left drivers window open and that control unit got soaked from a thunderstorm. When I got out to the truck, the window was going up and down by itself. I figured it was toast, but driving with the heater on for half hour dried it out and it's been fine ever since. Don't loan you Ram to anyone else and that control won't get broken again. (my case)
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
