Installed TLC in my 2013 Ram...NICE SYSTEM! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 10-27-2013, 08:34 AM
ALLPAR's Avatar
ALLPAR ALLPAR is offline
Vehicle: 2013 Ram 1500 Sport 4X4
Trim Level: Sport Crew Cab
Rep:100
ALLPAR will become famous soon enoughALLPAR will become famous soon enough
Default Installed TLC in my 2013 Ram...NICE SYSTEM!
Finally got around to getting the system installed in my 13 Ram this weekend. Install was very simple and didn't take long at all. The longest part of the whole install was figuring out where I wanted to mount the compressor and then clean up/securing wires & hoses. It worked great and had no leaks...I inflated them to 20psi and left over night to make sure there was no bleeding down...stayed right where I set it! Right now I'm running 5psi in there but haven't had much of a chance to really test them out, but will this week at work. I'm gonna fabricate a box to route around the compressor to protect it a little more from debris and the weather...I have it mounted currently on the drivers frame rail. It would probably hold up fine in the weather where its located, but for my own peace of mind I would prefer it to be protected a little more. My install does not differ much from ArmyofOne's install in another thread, but I will post pics of the few things I did do differently.
2013 Ram 1500 4x4 CC Sport
Magnaflow exhaust, S&B CAI, Bully Dog Hemi+ tune, Bilstein 5100 set at 2.1, TLC air bag suspension, BT Catch Can, Vanish Low Profile tonneau cover, cabin air filter, AMSOIL fluids
***It's not Jet Noise, It's the Sound of Freedom!***
Old 11-18-2013, 07:22 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1230
Glad you like it! I actually ended up moving my compressor to the front crossmember so it is protected from the elements by the front bumper.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
