Old 10-27-2013, 01:32 PM
jaybbowjay jaybbowjay is offline
Vehicle: 1997 Ram
jaybbowjay is on a distinguished road
Default Random misfire #3 #6 #8
I just purchased a 1997 Dodge ram 1500 knowing it had an engine problem. The truck has a pretty bad misfire and loss of power. When I purchased it it felt as if it maybe only had one dead cylinder, but after getting the DTC codes it seems that its more complex. Ive ran a compression test, and all cylinders range between 140 -165 PSI except #3 is around 130 PSI range. Ive replaced both Oxygen censors, IAC valve, CPS sensor, and replace the fuel injectors for the 3 cylinders with the misfire. The truck idles a little better after all this, but still has the problem. Under load it shakes, and even at idle you can hear a crackle once in a while from the exhaust. There is a very rich fuel smell from the exhaust, it stinks up the whole house in back. And I havent driven it much, other then testing, but im guessing there is heavy oil consumption, because it was low, and you can see a little blue smoke when revving. Just wondering if just the plenum gasket could cause all of this, or if maybe I have some bad heads also.
Old 10-27-2013, 01:34 PM
Vehicle: 1997 Ram
Ive read that the head castings for this engine were on the thin side, and they are prone to cracking in the combustion chambers. Is there a cast iron replacement with the problem corrected?
Old 10-28-2013, 07:29 PM
Vehicle: 1997 Ram
Pulled the intake today, definitely bad plenum gasket, oil pooling in ther when I removed it. Intake bolts seemed loose also, and the intake lifted of very easy, I expected it to be sealed, or stuck.
