Old 10-27-2013, 03:08 PM
hativsskoll hativsskoll is offline
Vehicle: 2011 RAM 1500 SLT 4x4
Color: RED
hativsskoll is on a distinguished road
Question 2011 RAM will possible electrical issues???? !!! HELP !!!
Hello everyone,
I'm new here. Seeking wisdom from fellow Mopar and RAM fans!
I have a 2011 RAM 1500, SLT, 4x4, HEMI, Quad cab. I bought it used this spring with under 42K miles on it. In less than 6 months I've put close to 13k on it. Flawless absolutely no issues! UNTIL last week. Here's what happened. Usual morning getting ready for work. I jumped in and start'er up with no issues however immediately I noticed all my gages ( RPM, Fuel, MPH etc ) gave no readings. No lights came on the dash ether ( check engine, seat belt, break etc). The wiper blades were running full blast and would not respond to the wiper blade controls in the cab. Washer fluid wouldn't spray ether. I shut the truck off and opened the door. The cab lights didn't come on and it didn't "ding ding ding" to tell me the key was in the ignition. I pulled the battery cables to reset the system. Started'er up again and still showed the same issues. In addition I noticed the front headlights wouldn't react to the headlight switch in the cab and the blinkers would not work. Left, right and hazard lights. I fooled with it about 20 minutes. After the fourth restart and two battery cable disconnects. Everything fired up as if nothing was ever wrong. This was Thursday morning. Friday no issue. But then on Saturday and Sunday mornings it acted up on me again with the same issues. I've noticed it's always in the morning, And once the truck warms up. It quits the issues... We had a cold front push through Wednesday night. So Thursday, Friday, Saturday and Sunday mornings are the first time I've seen weather below 50o in this truck. However I can't see how cold weather could cause this??? I can drive it just like normal when it acts up. But just can't tell how fast I'm going, fuel level etc. No blinkers and the stupid wipers running full blast with no way to turn them off! But again, once it warms up or I put it in the sun for an hour it quits! HELP anyone?
Thanks!
Old 10-28-2013, 06:15 PM
SilverFire's Avatar
SilverFire SilverFire is offline
Vehicle: 1989 Holden Astra
Rep:25
SilverFire is on a distinguished road
I would first check your ECU out, look for cracks in the casing, or if there's any spots where it's not sealed properly.
If you're experienced with electronics, you can check the internals and see if there's a crack in one of the circuits, or possibly a blown cap.
Though I am thinking you have a cracked circuit somewhere, where the cold is causing it to separate. Your truck is new enough that I wouldn't suspect a leaking cap, though it could happen.
Also, I admit I am not familiar with the newer models, so I am unsure of whether or not they have a separate control module under the dash.
If you got the warranty transferred when you bought the truck, you should be able to take it in for diagnostics at no cost to yourself.
Hopefully someone with knowledge on the newer trucks will chime in and be able to give you more help!
Old 11-10-2013, 05:19 PM
dbuzz77's Avatar
dbuzz77 dbuzz77 is offline
Vehicle: 2009 Ram RCSB 4x4
Color: Stone White
Rep:100
dbuzz77 will become famous soon enoughdbuzz77 will become famous soon enough
some people have seen weird stuff with a dying battery
2009 RCSB Sport, SC Cortex, K&N air box, all Amsoil fluids, Fan delete, Grounded TB, homemade catch can, homemade gps mount, Fastman TB, EZ down tailgate, Bully hitch step
Then God made a hemi, and knew that it was good.
