Old 10-27-2013, 07:26 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Default Torque converter build?
I'm trying to figure out which TC to get, Edge or Circle D. I have emails out to both Andre and Chris. My question is though, I know some of the Circle D converters are just stock ones with rebuilt parts and some are complete custom built converters. I can't figure out this same thing with the Edge converters. I know Edge has only 3 available for our transmissions, but I don't know if all 3 are rebuilt OEM converters or custom built ones. Anyone know the answer?
Supercharged, cammed, other things too!
Old 10-27-2013, 08:44 PM
I push the skinny pedal
Rep:3308
The circle D I picked up wasn't a rebuilt OEM, but I know there are some out there. From everything I've gone through and seen on all my forums is the Circle D is good up to 3000 stall, then it's fairly loose, the Edge had the advantage in the higher stalls.
Kurtis
Old 10-27-2013, 09:12 PM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
I'm doing my cam swap soon and I was talking with Jacob at Inertia and he recommended a 3000 stall converter. I'm just trying to decide which converter to get.
I was reading some of the threads about edge and circle d on here and one of them mentioned that a few of the circle d ones are OEM with rebuilt parts and others are custom built. I'm just trying to figure out if that's the case with the edge converters.
Old 10-27-2013, 09:20 PM
Rep:3308
The only rebuilds that I've heard of from Edge were a few years ago and only on the mild street TCs. If you go with the street or pro you're getting a new converter. If you think about it, it's just the outer casing that's reused, the internals are totally different, it's no different than picking up a reman alternator... new internals, just a used casing. Just food for thought.
Kurtis
