Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 10-28-2013, 08:25 PM
tachel403's Avatar
tachel403 tachel403 is offline
Vehicle: 2011 Dodge Ram sport quad cab
Trim Level: sport
Color: blue
Rep:65
tachel403 will become famous soon enough
Default clunking on little bumps.
I hear and feel a clunking whenever I go over little bumps. im checked everything in rear and and its all tight. moving my way tot he front end now. only thing I found out of everything is the left tie rod looks like it has a little bit of play in it. not a lot but enough if trucks jacked and I move wheel. the tire will clunk side to side about 10-20 thou of play.at the tierod
Old 10-29-2013, 08:34 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
It could be your tie rod, judging from what you're describing.
You didn't say where the clunking is coming from, so it's hard for us to make a suggestion.
My truck will sometimes cause me passenger seat to thump and bump. It's annoying, and I haven't quite figured out what I can do to lesson it. I can place my hand on the seat, apply a little pressure and the sound goes away.
Exco
Bill
Old 10-29-2013, 03:08 PM
Trim Level: sport
Color: green
Rep:643
some people have hd to replace tie rods in the 11s.
Old 10-29-2013, 10:04 PM
Hemi Todd's Avatar
Hemi Todd Hemi Todd is offline
Vehicle: 2012 Dodge Ram 2500
Rep:59
Hemi Todd will become famous soon enough
Check your sway bar end links
Old 11-05-2013, 02:43 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:65
I replaced my left front tie rod end. It was 42 thou play in it. But clunking is still there. Almost sounds like its in the rear . but can ever so faintly feel a bump at my feet on the floor . I do not have the spare tire under the truck but have wrapped it with tape and tightened so does not move by hand
Old 11-05-2013, 02:46 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:65
I also have a 4 inch lift in it so I have longer sway bar links . the rear are poly bushings and I grabbed and have them a shake . don't seem to move . I've also grabbed and shook front ones no movement. But the front ones are the two rubber spacers sandwiched with the washer. Solid sway bar links .
Old 12-09-2013, 12:41 AM
Aksium's Avatar
Aksium Aksium is offline
Color: Blue
Rep:18
Aksium is on a distinguished road
Mine clunks because of the leveling kit not allowing the shocks to seat properly also told by dealer that it has started to wear the shocks out I would like to just remove the kit but don't have the tools nore area to do it gonna wait till I get my lift I guess
Old 12-17-2013, 12:19 PM
hemi deep hemi deep is offline
Vehicle: 2011 1500 Bighorn
Rep:65
hemi deep will become famous soon enough
Make sure the top of your front shocks, where they bolt up, that the nut is tight. If it's loose it will make a ton of noise.
